SQL Logger Error after update to Indigo 6.1.8
Mon Apr 25, 2016 10:23 am
lindehoff offline
After I upgraded to Indigo 6.1.8 I started to get a lot of SQL Logger Error, here i an example:
  SQL Logger Error                exception trying to insert row into table device_history_564722319 ("Sonos Play 1 - Kitchen") -- unable to modify table
  SQL Logger Error                ERROR:  column "alive" of relation "device_history_564722319" does not exist at character 558
The error are in the same nature but different tables and columns.
It is not specific to a device type it occurs for all devices types and variables.
Mon Apr 25, 2016 11:05 am
Re: SQL Logger Error after update to Indigo 6.1.8
Looks Like your db is corrupted
Mon Apr 25, 2016 11:31 am
lindehoff offline
I really hope not, I can access the database with pgAdmin.
Mon Apr 25, 2016 11:36 am
You could do
-Stop Indigo server
-Sqlite3 sqlitehistory .dump > dumpfile
Then
-SQLite3 newdb < dumpfile
Then
-mv newdb to sqlitehistory
All in the logs directory in indigo
Or
Try indigoutilities and select menu restore or something like this
That does step 2 and 3. And some more things.
As alway I suggest to do an hourly db copy of your sql-db then let timemachine do its thing
Mon Apr 25, 2016 11:55 am
lindehoff offline
kw123 wrote:
You could do
-Stop Indigo server
Then
Then
Or
I'm not using Sqlite, I use PostgreSQL.
Mon Apr 25, 2016 2:37 pm
We didn't change anything in the plugin (haven't for a long time). I don't know much about PostgreSQL, but is there some function to validate/repair databases? I'd recommend checking to make sure there's not something wrong with the db or db server.
Finally, you can attempt Karl's suggestion (without the details), which is to dump your database, then recreate the db - though I'd have no idea how to do it on PostgreSQL...
Mon Apr 25, 2016 8:47 pm
RogueProeliator offline
Try manually inserting a value into one of those tables via pgAdmin - perhaps will get a better error message if it is related to a server configuration (e.g. out of space or corrupt indices or something along those lines). I don't think there is enough to go on with that error in the Indigo Log.
Adam
