[ANSWERED]: SQL Logger error
Mon Jun 29, 2015 5:28 am
jens offline
Hey,
Get this error log now when I start the SQL, began after I switched to the new Z-Wave USB stick (z-wave.Me) ...
Please help :)
Mon Jun 29, 2015 9:47 am
Re: SQL Logger error
Indigo isn't able to connect to your PostgreSQL server. Are you sure it is running? Can you connect to it from another client or the command line?
Mon Jun 29, 2015 11:01 am
jens offline
Re: [ANSWERED]: SQL Logger error
How do you start it ?? has not tried to connect, do not know how to do it... sooorryy
//Jens
Mon Jun 29, 2015 11:41 am
//Jens
If you don't know how to start or connect to a PostgresSQL server, you should probably either disable the SQL Logger plugin, or switch it to SQLight.
Mon Jun 29, 2015 1:21 pm
FlyingDiver is correct. PostgreSQL is neither included nor installed by Indigo. There is no way Indigo can connect to it unless you have installed and configured it. The SQLite option will work out-of-the-box though.
Tue Jun 30, 2015 12:12 am
jens offline
Get this message now :( I can delete the old file and SQL creates a new ???
//Jens
Skärmavbild 2015-06-30 kl. 08.09.46.png (486.05 KiB) Viewed 5368 times
Tue Jun 30, 2015 4:46 am
Yes, you can delete the old .sqlite file and Indigo will create a new one. Make sure Indigo is not running (UI and server) when you do that.
Tue Jun 30, 2015 7:22 am
jens offline
Okey, thanks will try
Skickat från min D6603 via Tapatalk
Fri Jul 10, 2015 2:06 am
jens offline
Has now removed the SQL log file, but get the same error message :(
//Jens
Fri Jul 10, 2015 9:15 am
It sounds like there is a file/folder permission problem. Re-run the Indigo installer. It will attempt to fix some permission problems.
Sat Jul 11, 2015 3:15 am
jens offline
Will try
Mon Jul 13, 2015 2:46 am
jens offline
Still the same problem after Re-run the Indigo installer, some more idea :(
//Jens
Thu Jul 16, 2015 10:55 am
When you deleted the old indigo_history.sqlite file, did you make sure that both the Indigo client and Indigo Server were stopped first?
Sat Jul 18, 2015 10:25 am
jens offline
No client Was on :(
Sent from my iPhone 6 using Tapatalk
Sat Jul 18, 2015 10:26 am
jens offline
And mayby server
