[ANSWERED]: Can't find indigo_history.sqlite
Sun Mar 29, 2015 11:55 am
Nine offline
Even though the SQL Logger Plugin is enabled and no error is shown in the log, I can't find the SQLite-Database indigo_history.sqlite on my maschine... any hints?
The log says that SQL Logger is working:
  Z-Wave                          received "Motion Sensor Gang/Küche" status update is on
  SQL Logger Debug                state change list for "Motion Sensor Gang/Küche": [(u'onOffState', True)]
  SQL Logger Debug                INSERT INTO device_history_1081114426 ("batterylevel", "batterylevel_ui", "onoffstate") VALUES (?, ?, ?);
  SQL Logger Debug                     (u'100', u'100%', u'True')
Sun Mar 29, 2015 4:30 pm
Re: Can't find indigo_history.sqlite
In the log window, click on the button labelled "Show Event Logs Folder", and you should be able to find it there.
Dave
Tue Mar 31, 2015 7:12 am
Nine offline
In that folder are only my log-files ... but no *.sqlite :roll:
Tue Mar 31, 2015 8:15 am
Hmm. I think the location is set by the plugin so it *should* be there.
Tue Mar 31, 2015 8:51 am
RogueProeliator offline
If you open the SQL Logger Plugin Configuration (Plugins->SQL Logger->Configure) there is a box for entering the SQLite file. Is this not filled in?
At any rate, you can drop to a Terminal window and enter:
find /Library/Application\ Support/ -name "*.sqlite"
If it is outside the base directory, may need to expand to use / instead of /Library/Application\ Support/ but you might get lots of permissions errors as it searches (won't hurt anything, just have to look through them to find the file...)
Adam
Tue Mar 31, 2015 10:16 am
Nine offline
ahhhh good old terminal :D says my file is here:
/Library/Application Support//Perceptive Automation/Indigo 6/Plugins/SQL Logger.indigoPlugin/Contents/Server Plugin/indigo_history.sqlite
but I did not enter a path in the plugin-configuration...
Tue Mar 31, 2015 6:54 pm
Re: [ANSWERED]: Can't find indigo_history.sqlite
That is strange – I'm not sure how it ended up in there (or why it was created there originally if that is the case).
