sql example code
Fri Feb 21, 2014 8:46 pm
sql example code
is there anywhere an example python on how to access and use the sql data?
Sat Feb 22, 2014 8:33 am
RogueProeliator offline
Re: sql example code
Are you referring to the SQL Logger plugin's data? If so, send me a PM with your email and I can send some code your way that you can pretty much drop in to a plugin.
Adam
Sat Feb 22, 2014 12:25 pm
thanks.. did send you an email
Wed Mar 05, 2014 11:34 am
I am trying it out as we speak .. and I get
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/testsql.indigoPlugin/Contents/Server Plugin/reqhandler.py", line 20, in <module>
<type 'exceptions.ImportError'>: No module named indigopy
I am including reqhandler.py from the same directory as plugin.py and added dataAccess directory.
could not find anything thats indigopy
any suggestion welcome
Wed Mar 05, 2014 12:42 pm
Should it be indigo.py :?:
Wed Mar 05, 2014 12:45 pm
That request handler is from an IWS plugin... You'll just want to copy the sample functions into your plugin if you are just testing. The only extra include should be the dataAccess one (I forget the actual name, don't have it with me right at this moment).
You should be OK for testing but a full plugin should likely change the configuration from reading the file directly to using the IOM.
Adam
Wed Mar 05, 2014 2:11 pm
got that , running now but I don't get a connection
in getDatabaseConnection()
dbConfig = self.readSQLLoggerPreferences(sqlLoggerPrefPath)
gets back: {'dbType': 0, 'dbName': '/Library/Application Support/Perceptive Automation/Indigo 6/Logs/indigo_history.sqlite'}
= does not find/recognize sqlite .. dbType =0?
in a terminal window I can get to sqlite and get data
I have copied from getVariableHistory(self,...) down into my plugin and imported "from dataAccess import indigosql"
thanks
Wed Mar 05, 2014 2:46 pm
Update: when I "comment" self._Log(..) i.e. put # in front of it in IndigoSqlite(IndigoSql) it works..
I checked the code: the logfile is handed over as None:
indigosql.IndigoSqlite(dbConfig["dbName"], None, None, None)
and
def __init__(self, sql_lite_db_file, sleepFunc, logFunc, debugLogFunc):
IndigoSql.__init__(self, kDbType_sqlite, sleepFunc, logFunc, debugLogFunc)
is that not correct?
Wed Mar 05, 2014 2:53 pm
talking to my self again... that seems to work fine.. anyway
should I replace the log file parameter "None" (2. and 3 None) with "indigo.server.log" in
"indigosql.IndigoSqlite(dbConfig["dbName"], None, None, None)"
so that
"def __init__(self, sql_lite_db_file, sleepFunc, logFunc, debugLogFunc)"
has a log function?
Wed Mar 05, 2014 3:59 pm
so that
has a log function?
Yes, pass indigo.server.log for logFunc, and optionally pass it for debugLogFunc if you are trying to debug the SQL being sent/received.
Wed Mar 05, 2014 4:42 pm
thanks that seems to work
on to the next:
the variable query seems to return hex code
[(234, datetime.datetime(2014, 3, 5, 5, 54, 24), u'00:0E:58:41:6C:D6;14:8F:C6:74:87:58;00:1F:5B:30:E9:21;10:9A:DD:60:97:2C'), (233, datetime.datetime(2014, ...
while the device query seems to return numbers as strings:
[(u'False', u'False', u'False', 1, 76473, u'False', 0, u'False', datetime.datetime(2014, 3, 5, 22, 20, 55), u'73 \xb0F', u'False', u'False', u'False', 73, u'73', u'True', u'heat on', u'73 \xb0F', u'80 \xb0F', 80, u'False', u'True', u'False', 73, u'False', u'False', u'auto on'), (u'False', u'False', u'False', 1, 76472, u'False', 0, u'False', ...
although the query seems similar..
and the "same" difference when run in a terminal..
On purpose?
Thanks for all the help
Wed Mar 05, 2014 4:47 pm
sorry for the confusion ... the variable had the Mac's MAC address in hex code as value .. and that was returned ..
Wed Mar 05, 2014 8:05 pm
Ok, sounds like you got it working ok, then? Sorry for the delay, have been in the middle of the Smokey mountains this week, though heading back to "low lands" tomorrow so should be back fully connected in the evening.
Note that MUCH of that code comes from Perceptive Automation's SQL Logger data access code which Matt graciously agreed could be used in plugins (you may have noticed that in the copyright statement at the top). I have refactored some of it a bit but have not yet factored in their recent changes for keyword-based columns. Not likely to affect you in any way but I'll update that code just the same and send you the revisions.
Adam
Wed Mar 05, 2014 9:58 pm
thanks so much for your help.. i am now in the process of merging the sql data source into indigo plot...
Thu Mar 06, 2014 10:11 pm
[['signalstrength','maxhumidity','onoffstate','temperature','brightnesslevel','humiditystatus','mintemperature','ts','lastupdated','humidity','minhumidity','voltage','maxtemperature','id','message','batterylevel','type','display','resetdayvalue'],['integer','integer','bool','integer','integer','text','integer','timestamp default current_timestamp','text','integer','integer','integer','integer','integer primary key','text','integer','integer','text','integer'],[(6, 34, None, 67.799999999999997, None, u'normal', 67.099999999999994, datetime.datetime(2014, 3, 7, 4, 6, 30), u'2014/03/06 22:05:47', 34, 33, None, 69.099999999999994, 139679, None, 10, 1, u'68.0 F / 34%', None), (6, 34, None, 67.799999999999997, None, u'normal', 67.099999999999994, datetime.datetime(2014, 3, 7, 4, 6, 30), u'2014/03/06 22:06:30', 34, 33, None, 69.099999999999994, 139680, None, 10, 1, u'67.8 F / 34%', None), (6, 34, None, 68, None, u'normal', 67.099999999999994, datetime.datetime(2014, 3, 7, 3, 59, 20), u'2014/03/06 21:58:37', 34, 33, None, 69.099999999999994, 139677, None, 10, 1, u'68.2 F / 34%', None), (6, 34, None, 68, None, u'normal', 67.099999999999994, datetime.datetime(2014, 3, 7, 3, 59, 20), u'2014/03/06 21:59:20', 34, 33, None, 69.099999999999994, 139678, None, 10, 1, u'68.0 F / 34%', None), (6, 34, None, 68.200000000000003, None, u'normal', 67.099999999999994, datetime.datetime(2014, 3, 7, 3, 57, 54), u'2014/03/06 21:57:11', 34, 33, None, 69.099999999999994, 139675, None, 10, 1, u'68.0 F / 34%', None), (6, 34, None, 68.200000000000003, None, u'normal', 67.099999999999994, datetime.datetime(2014, 3, 7, 3, 57, 54)...
I get this back from ret= self.getDeviceHistory(theDeviceId)
looks like a list but is just a string? How can I convert this to a list?
do I need to do: eval(ret, {'__builtins__':[]}, {}) or something like that? [EDIT] gives an error message datetime not defined (have included it)
