Feature Request - Suppress NOAA Weather Changes to Log
Sat Nov 11, 2023 10:29 am
ryanbuckner offline
I get this update in the logs every time the NOAA plugin updates the weather. It would be great to have a device setting to suppress this log entry and only log errors. Also, the timestamp doesn't match the Indigo server log time.
Nov 11, 2023 at 9:38:49 AM
   NOAA Weather                    'IAD NOAA Weather' changed at 2023-11-11 08:52:00'.
Sat Nov 11, 2023 2:55 pm
Re: Feature Request - Suppress NOAA Weather Changes to Log
I'll add your suggestion to the list -- it should theoretically be an easy change to the code.
The reason that the log message timestamp doesn't match the Indigo server time:
  • The timestamp in the log is the time the data was changed in the NOAA API.
  • The server timestamp is the time the Indigo device was last updated.
The difference is meant to give some idea how old the weather data actually are.
Sun Nov 12, 2023 7:57 am
ryanbuckner offline
Got it, thanks. In the meantime I just changed those logs from info to debug and I'm all set.
Sun Nov 12, 2023 8:24 am
Just note that your changes may be overwritten if you re-run the Indigo installer.
Sun Nov 12, 2023 10:32 am
ryanbuckner offline
noted. Thanks
