iTunes starts playing by itself?
Wed Aug 16, 2017 2:18 pm
Colly offline
Hi Folks,
I run my Indigo install on a headless Mac Mini and even with the iTunes Plugin disabled it randomly starts playing. I don't use my Mac Mini for anything else so I'm baffled as to what is going on and how it seemingly starts playing by itself. Common sense would tell me it's nothing to do with Indigo but as stated above I don't do anything else but Indigo on it.. Any help would be appreciated
Colly
Wed Aug 16, 2017 2:23 pm
Re: iTunes starts playing by itself?
Are you absolutely sure you don't have any Indigo AppleScripts that target iTunes? Those would not require the iTunes plugin.
Wed Aug 16, 2017 2:28 pm
Colly offline
Not that I'm aware of anyhow. I've never tried AppleScripts as its beyond my current capabilities.
Wed Aug 16, 2017 3:27 pm
Check the Event Log window when it starts up and see if there's anything there. If the plugin is disabled then it's definitely not that. It could be a script though as @Different Computers points out. If there's nothing in the event log, then it's unlikely it has anything to do with Indigo.
Also, does the Mac that you have running the Indigo Server have an IR receiver? If so, maybe you're using an Apple Remote for something else (like an Apple TV) and the signal is leaking to the Mac occasionally? That used to periodically happen to me (many years ago with a MacBook that had an IR receiver built-in).
Wed Aug 16, 2017 3:43 pm
Colly offline
Jay you're a STAR!
The Mac Mini is located close to an Apple TV and sure as hell once I played with the Apple TV remote iTunes started playing. :lol:
Consider it sorted..
