Controlling EasyDAQ via Python Question
Posted: Tue Jul 11, 2017 11:20 am
From the scripting shell, I can see that the EasyDAQ description looks like what's at the bottom of this post. How do I go about turning a specific relay on and off via a Python script given this?
Blaine
Blaine
- Code: Select all
address : /dev/cu.usbserial-A50169OP
batteryLevel : None
buttonGroupCount : 0
configured : True
description : 8 channel relay + 8 relay or DIO card + 8 DIO (240VAC @ 10A)
deviceTypeId : easyDaq16r8io
displayStateId : allChannels
displayStateImageSel : None
displayStateValRaw : 1, 0, 0, 0, 0, 0, 0, 1, 0, 1, 0, 0, 0, 0, 0, 1, 1, 1, 1, 0, 1, 1, 1, 1
displayStateValUi : 1, 0, 0, 0, 0, 0, 0, 1, 0, 1, 0, 0, 0, 0, 0, 1, 1, 1, 1, 0, 1, 1, 1, 1
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 0
com.perceptiveautomation.indigoplugin.easydaq-usb-relay-cards : (dict)
channel01.label : Relay 1 - Main Cistern Pump to Day Tank (string)
channel02.label : Relay 2 - First Flush Pump (string)
channel03.label : Relay 3 - Day Tank Pump (string)
channel04.label : Relay 4 - First Flush 3-Way Valve - Sediment Purge (string)
channel05.label : Relay 5 - First Flush 3-Way Valve - Cistern Fill (string)
channel06.label : Relay 6 - ET Water Rain Sensor Simulator (string)
channel07.label : Relay 7 (string)
channel08.label : Relay 8 - Computer Online Indicator (string)
channel09.label : IO 9 - First Flush 3-Way Valve Sediment Purge Position (string)
channel09.type : isInput (string)
channel10.label : IO 10 - First Flush 3-Way Valve Cistern Fill Position (string)
channel10.type : isInput (string)
channel11.label : IO 11 - Day Tank Empty Float (string)
channel11.type : isInput (string)
channel12.label : IO 12 - Day Tank Full Float (string)
channel12.type : isInput (string)
channel13.label : IO 13 - Day Tank Pump Pressure Sense (string)
channel13.type : isInput (string)
channel14.label : IO 14 (string)
channel14.type : isOutput (string)
channel15.label : IO 15 (string)
channel15.type : isOutput (string)
channel16.label : IO 16 - Cistern Main Pump Pressure Sense (string)
channel16.type : isInput (string)
channel17.label : IO 17 - Cistern Empty Float (string)
channel17.type : isInput (string)
channel17to24label : (string)
channel18.label : IO 18 - Cistern 1/3 Full Float (string)
channel18.type : isInput (string)
channel19.label : IO 19 - Cistern 2/3 Full Float (string)
channel19.type : isInput (string)
channel1to8label : (string)
channel20.label : IO 20 - Cistern Full Float (string)
channel20.type : isInput (string)
channel21.label : IO 21 - First Flush Empty Float (string)
channel21.type : isInput (string)
channel22.label : IO 22 - First Flush 1/3 Full Float (string)
channel22.type : isInput (string)
channel23.label : IO 23 - First Flush 2/3 Full Float (string)
channel23.type : isInput (string)
channel24.label : IO 24 - First Flush Full Float (string)
channel24.type : isInput (string)
channel9to16label : (string)
devicePort_serialConnType : local (string)
devicePort_serialPortLabel : (string)
devicePort_serialPortLocal : /dev/cu.usbserial-A50169OP (string)
devicePort_serialPortNetRfc2217 : rfc2217:// (string)
devicePort_serialPortNetSocket : socket:// (string)
devicePort_uiAddress : /dev/cu.usbserial-A50169OP (string)
sep2 : (string)
sep3 : (string)
sep4 : (string)
lastChanged : 2017-07-11 09:03:03
model : EasyDAQ USB16PRMxN / NET16PRMx (8 relays + 8 relays/DIO + 8 DIO channels)
name : USB16PRMxN - Rainwater Catchment Controller
ownerProps : com.perceptiveautomation.indigoplugin.easydaq-usb-relay-cards : (dict)
sep2 : (string)
sep3 : (string)
sep4 : (string)
pluginId : com.perceptiveautomation.indigoplugin.easydaq-usb-relay-cards
protocol : Plugin
remoteDisplay : True
states : States : (dict)
allChannels : 1, 0, 0, 0, 0, 0, 0, 1, 0, 1, 0, 0, 0, 0, 0, 1, 1, 1, 1, 0, 1, 1, 1, 1 (string)
channel01 : on (on/off bool)
channel02 : off (on/off bool)
channel03 : off (on/off bool)
channel04 : off (on/off bool)
channel05 : off (on/off bool)
channel06 : off (on/off bool)
channel07 : off (on/off bool)
channel08 : on (on/off bool)
channel09 : off (on/off bool)
channel10 : on (on/off bool)
channel11 : off (on/off bool)
channel12 : off (on/off bool)
channel13 : off (on/off bool)
channel14 : off (on/off bool)
channel15 : off (on/off bool)
channel16 : on (on/off bool)
channel17 : on (on/off bool)
channel18 : on (on/off bool)
channel19 : on (on/off bool)
channel20 : off (on/off bool)
channel21 : on (on/off bool)
channel22 : on (on/off bool)
channel23 : on (on/off bool)
channel24 : on (on/off bool)
subModel :
supportsAllOff : False
supportsStatusRequest : False
version : 0
