[SOLVED]: Indigo 6 - how to display states?
Mon Apr 27, 2015 6:50 pm
zurich offline
Using the EASYDAQ BOARDS as example; in Indigo 5, the window at the bottom of the DEVICES shows the states of all the channels, in Indigo 6 in the window (now called Device Details) all I get is the last update. How can I get it to display all the channel states same like Indigo 5?
thanks to you,
Zurich
Mon Apr 27, 2015 8:15 pm
Re: Indigo 6 - how to display states?
Grab the tiny shaded round circle that is between the top of the Device Details section of the window and the bottom of the device table, then drag it up. That will resize the lower section and reveal the states. I definitely agree we should make that more discoverable, by stacking those two views horizontally in cases such as this where they both fit.
Mon Apr 27, 2015 9:45 pm
zurich offline
Re: [SOLVED]: Indigo 6 - how to display states?
Ah sehr gut! but the device details have a large window and only show a date. Maybe make this Device Details window sizeable or a "hide" button to give more room for the Custom States window? Or even the windows side by side?
good thanks to you for help!
Z
