Please assist with EasyDaq NET16PRMX
Mon Aug 25, 2014 3:29 pm
zurich offline
GREETINGS
I been using Easy-Daq USB relays boards for some time with gut success. I lately try to use the NET16PRMX. I used Arp - a to find IP of the board and enter in Indigo Configuration socket://169.254.108.229:10001. Normally this work OK but some times in the day I get the following errors:
2014-08-25 14:54:04 EasyDAQ Relay Card Error failed to read state from device "NET16" for channel indices 1 to 8
2014-08-25 14:54:00 EasyDAQ Relay Card Error failed to read state from device "NET16" for channel indices 9 to 16
2014-08-25 14:54:07 EasyDAQ Relay Card Error failed to read state from device "NET16" for channel indices 17 to 24
I have the board plugged into an ethernet hub connected to an Airport Extreme. The computer with Indigo is plugged into same ethernet hub.
I think the plugin continually loops reading inputs and relays to look for any change but sometime cannot read from the board and give above error.
I look for any suggestions to make this board more reliable.
Mon Aug 25, 2014 7:24 pm
Re: Please assist with EasyDaq NET16PRMX
You are correct that Indigo has to continuously poll the status of the board to read the inputs.
When the errors are logged in the Event Log is something failing? Does it recover?
Fri Aug 29, 2014 5:57 pm
zurich offline
Thanks to you for kind reply.
No, no other errors. I had 2 days no errors then this morning 4 lines in log of unable to read indices then recovers again. I think perhaps communication over network is more susceptible
to errors than using USB. I use 2 USB boards and never have this error.
Do you think if I slow down the polling interval slightly it may help? If so is it possible to do this?
thanks to you
Sat Aug 30, 2014 1:56 pm
I think you are correct – it is likely network hiccups that are causing the errors. There is no way to change the polling interval time. As long as it recovers, I would recommend just ignoring the errors in the Event Log.
Thu Nov 12, 2015 3:20 pm
pacman offline
I am a little desperate!
I updated my Insteon PLM, 2412U to 2413U, and did all the syncing of devices as required. Now both of my EasyDAQ Net16PRMx boards are showing "connection error" under Device status. I restarted Indigo Server and rebooted my router (several times) but both remain off line with no connection. Unfortuneately I am very dependent on these board to run my household.
Please advise.
Thu Nov 12, 2015 3:46 pm
pacman offline
OK - sorry for the panic. I got all my devices back on-line. I had to disconnect power to the Easy DAQ cards and re-energize them. Then my DCS (security system) plug-in stopped communicating so I had to unplug the battery and power from that card and re-energize. I am guessing it is a hand shaking, squencing thing. I do have a monster on my hands here: works great most of the time but when it goes bad it takes some trial and error to get things working right.
Mon Nov 30, 2015 9:27 am
pacman offline
There is something in conflict with both my NET DAQ boards and my DCS security panel each time I reboot my host computer. The only change in my household is a new AppleTV (newest version). After reboot the above mentioned boards do not connect so I have to disconnect power from them in order to get the IP address to connect, Rebooting the router does not make a difference. Perhaps I have a port conflict.
Anyone have something remotely similar happening?
Is there a range of safe ports I can try compatible with Indigo Server and related hardware and plug-ins? My DAQ cards use 10001 & 10002, both user configurable, I think. Not sure about the DCS panel.
Fri Jan 22, 2016 9:21 am
pacman offline
With some more frequency my NetDAQ16 boards are acting up. This morning, shortly after midnight ,my garage doors were opened and I started getting alarms. This woke me up, and in a fog, I realized my DAQ1 board was offline (I couldn't turn of the activated relays). I had to reload the EasyDAQ pulg-in so I could reset the relay condition(s). Here is my log from 00:00 to 01:49 with all the activity - perhaps you can see something. There is a schedule that runs nightly to reset my HW Circ Pump.
Perhaps someone familiar with these EasyDAQ Net16 broads can see something in the log that is askew. Thanks
2016-01-14 00:00:00.572 Application Created new log file (Indigo Server version 6.1.4)
2016-01-14 00:03:22.172 Received INSTEON "T-Stat" temperature changed to 67.0
2016-01-14 00:04:28.510 Received INSTEON "T-Stat" temperature changed to 66.0
2016-01-14 00:10:00.496 Schedule HWcirc Rest
2016-01-14 00:10:00.497 Action Group HWcirc Enable OFF
2016-01-14 00:10:00.541 EasyDAQ Relay Card sending "DAQ Card 1 - Enable HW Circ(8)" off
2016-01-14 00:10:00.600 EasyDAQ Relay Card received "DAQ Card 1 - PE Power(9)" update to on
2016-01-14 00:10:00.605 EasyDAQ Relay Card received "DAQ Card 1 - AUX Power(10)" update to on
2016-01-14 00:10:00.610 EasyDAQ Relay Card received "DAQ Card 1 - Shunt Patio Motion(11)" update to on
2016-01-14 00:10:00.612 Trigger DRM Vol Adjust (furnace OFF)
2016-01-14 00:10:00.614 EasyDAQ Relay Card received "DAQ Card 1 - Furnace Fan State(12)" update to on
2016-01-14 00:10:00.622 EasyDAQ Relay Card received "DAQ Card 1 - Alarm Bypass(13)" update to on
2016-01-14 00:10:00.628 EasyDAQ Relay Card received "DAQ Card 1 - Spare(HWpanel)(14)" update to on
2016-01-14 00:10:00.631 EasyDAQ Relay Card received "DAQ Card 1 - Spare(HWpanel)(15)" update to on
2016-01-14 00:10:00.663 Trigger Sonos Volume DRM
2016-01-14 00:10:01.063 Sent INSTEON "HW Circ Pump Switch Laundry" off
2016-01-14 00:10:01.522 Schedule HWcirc Rest (delayed action)
2016-01-14 00:10:02.279 Sent INSTEON "HW Circ Pump Switch MBR" off
2016-01-14 00:10:02.461 Trigger Garage Alarm 2 Watch ON
2016-01-14 00:10:02.465 DSC Alarm Alarm Zone 'DSC Z04 (garagemain2)' Opened.
2016-01-14 00:10:02.472 Trigger Garage Alarm 1 Watch ON
2016-01-14 00:10:02.475 DSC Alarm Alarm Zone 'DSC Z01 (garagemain1)' Opened.
2016-01-14 00:10:03.238 Sent INSTEON "HW Circ Pump Switch Bath" off
2016-01-14 00:10:03.318 Sent INSTEON "PowerLinc Interface" off (scene 49 - SwitchLinc 8_6)
2016-01-14 00:10:04.597 Sent INSTEON "Coffee Switch Manual/Reset" off (scene 49 cleanup)
2016-01-14 00:10:04.677 Sent INSTEON "PowerLinc Interface" on (scene 53 - SwitchLinc 8_4)
2016-01-14 00:10:05.636 Sent INSTEON "Coffee Switch Manual/Reset" on (scene 53 cleanup)
2016-01-14 00:10:05.716 Sent INSTEON "PowerLinc Interface" on (scene 51 - SwitchLinc 8_2)
2016-01-14 00:10:06.644 Sent INSTEON "Coffee Switch Manual/Reset" on (scene 51 cleanup)
2016-01-14 00:10:36.810 EasyDAQ Relay Card received "DAQ Card 1 - House Buzz(5)" update to off
2016-01-14 00:10:42.404 EasyDAQ Relay Card received "DAQ Card 1 - House Buzz(5)" update to on
2016-01-14 00:10:42.845 EasyDAQ Relay Card received "DAQ Card 1 - House Buzz(5)" update to off
2016-01-14 00:10:48.881 EasyDAQ Relay Card received "DAQ Card 1 - House Buzz(5)" update to on
2016-01-14 00:11:06.501 Application Indigo Cocoa client authenticated (192.168.0.206)
2016-01-14 00:11:14.729 WebServer undefined page requested "http://glaciercam1.dyndns.tv:8176/apple-touch-icon-120x120-precomposed.png" from 192.168.0.8
2016-01-14 00:11:14.740 WebServer undefined page requested "http://glaciercam1.dyndns.tv:8176/apple-touch-icon-120x120.png" from 192.168.0.8
2016-01-14 00:11:22.493 EasyDAQ Relay Card sending "DAQ Card 1 - Back Buzz(4)" off
2016-01-14 00:11:22.551 Trigger DRM Vol Adjust (furnace ON)
2016-01-14 00:11:22.554 EasyDAQ Relay Card received "DAQ Card 1 - Furnace Fan State(12)" update to off
2016-01-14 00:11:22.556 EasyDAQ Relay Card received "DAQ Card 1 - HW Circ Pump State(16)" update to on
2016-01-14 00:11:22.606 Trigger Sonos Volume DRM
2016-01-14 00:11:22.675 EasyDAQ Relay Card received "DAQ Card 1 - don't use!" update to off
2016-01-14 00:11:26.636 EasyDAQ Relay Card sending "DAQ Card 1 - House Buzz(5)" off
2016-01-14 00:11:26.697 Trigger DRM Vol Adjust (furnace OFF)
2016-01-14 00:11:26.699 EasyDAQ Relay Card received "DAQ Card 1 - Furnace Fan State(12)" update to on
2016-01-14 00:11:26.707 EasyDAQ Relay Card received "DAQ Card 1 - Alarm Bypass(13)" update to off
2016-01-14 00:11:26.742 Trigger Sonos Volume DRM
2016-01-14 00:11:27.927 EasyDAQ Relay Card sending "DAQ Card 1 - House Buzz(5)" off
2016-01-14 00:11:29.876 EasyDAQ Relay Card sending "DAQ Card 1 - House Buzz(5)" on
2016-01-14 00:11:29.937 EasyDAQ Relay Card received "DAQ Card 1 - Alarm Bypass(13)" update to on
2016-01-14 00:11:34.001 EasyDAQ Relay Card sending "DAQ Card 1 - Back Buzz(4)" on
2016-01-14 00:11:35.414 WebServer undefined page requested "http://glaciercam1.dyndns.tv:8176/apple-touch-icon-120x120-precomposed.png" from 192.168.0.8
2016-01-14 00:11:35.422 WebServer undefined page requested "http://glaciercam1.dyndns.tv:8176/apple-touch-icon-120x120.png" from 192.168.0.8
2016-01-14 00:11:36.794 EasyDAQ Relay Card sending "DAQ Card 1 - Back Buzz(4)" off
2016-01-14 00:11:36.855 Trigger DRM Vol Adjust (furnace ON)
2016-01-14 00:11:36.857 EasyDAQ Relay Card received "DAQ Card 1 - Furnace Fan State(12)" update to off
2016-01-14 00:11:36.898 Trigger Sonos Volume DRM
2016-01-14 00:11:39.047 EasyDAQ Relay Card sending "DAQ Card 1 - Back Buzz(4)" off
2016-01-14 00:12:05.295 Application Reloading plugin "EasyDAQ Relay Card 1.1.7"
2016-01-14 00:12:05.297 Application Stopping plugin "EasyDAQ Relay Card 1.1.7" (pid 40379)
2016-01-14 00:12:05.797 EasyDAQ Relay Card closed connection to device "DAQ Card 1"
2016-01-14 00:12:06.209 EasyDAQ Relay Card closed connection to device "DAQ Card 2"
2016-01-14 00:12:06.225 EasyDAQ Relay Card closed connection to device "DAQ Relay Board (8)"
2016-01-14 00:12:07.273 Application Stopped plugin "EasyDAQ Relay Card 1.1.7"
2016-01-14 00:12:08.779 Application Starting plugin "EasyDAQ Relay Card 1.1.7" (pid 54666)
2016-01-14 00:12:12.672 Application Started plugin "EasyDAQ Relay Card 1.1.7"
2016-01-14 00:12:13.217 EasyDAQ Relay Card connected to device "DAQ Relay Board (8)" on /dev/cu.usbserial-00007314
2016-01-14 00:12:13.219 EasyDAQ Relay Card channel status polling disable for device "DAQ Relay Board (8)"
2016-01-14 00:12:13.266 EasyDAQ Relay Card received "DAQ Card 1 - Pulse Garage Main(1)" update to on
2016-01-14 00:12:13.268 EasyDAQ Relay Card received "DAQ Card 1 - Pulse Garage Main(2)" update to on
2016-01-14 00:12:13.270 EasyDAQ Relay Card received "DAQ Card 1 - Cricket Cam Power(3)" update to on
2016-01-14 00:12:13.276 EasyDAQ Relay Card received "DAQ Card 1 - Back Buzz(4)" update to off
2016-01-14 00:12:13.279 EasyDAQ Relay Card received "DAQ Card 1 - House Buzz(5)" update to on
2016-01-14 00:12:13.281 EasyDAQ Relay Card received "DAQ Card 1 - Irrigation(6)" update to on
2016-01-14 00:12:13.283 EasyDAQ Relay Card received "DAQ Card 1 - Spare(7)" update to on
2016-01-14 00:12:13.286 EasyDAQ Relay Card received "DAQ Card 1 - Enable HW Circ(8)" update to on
2016-01-14 00:12:13.288 EasyDAQ Relay Card connected to device "DAQ Card 1" on socket://192.168.0.60:50021
2016-01-14 00:12:13.289 EasyDAQ Relay Card configured device "DAQ Card 1" channels 12, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24 as inputs
2016-01-14 00:12:13.291 EasyDAQ Relay Card received "DAQ Card 2 - DAS SAT(L)" update to off
2016-01-14 00:12:13.293 EasyDAQ Relay Card received "DAQ Card 2 - DAS SAT(R)" update to off
2016-01-14 00:12:13.296 EasyDAQ Relay Card received "DAQ Card 2 - DAS AUX(L)" update to off
2016-01-14 00:12:13.298 EasyDAQ Relay Card received "DAQ Card 2 - DAS AUX(R)" update to off
2016-01-14 00:12:13.300 EasyDAQ Relay Card received "DAQ Card 2 - DAS SONOS(L)" update to on
2016-01-14 00:12:13.303 EasyDAQ Relay Card received "DAQ Card 2 - DAS SONOS(R)" update to on
2016-01-14 00:12:13.305 EasyDAQ Relay Card received "DAQ Card 2 - DAS DEN(L)" update to off
2016-01-14 00:12:13.307 EasyDAQ Relay Card received "DAQ Card 2 - DAS DEN(R)" update to off
2016-01-14 00:12:13.308 EasyDAQ Relay Card connected to device "DAQ Card 2" on socket://192.168.0.62:50022
2016-01-14 00:12:13.308 EasyDAQ Relay Card configured device "DAQ Card 2" channels 17, 18, 19, 20, 21, 22, 23, 24 as inputs
2016-01-14 00:12:13.310 EasyDAQ Relay Card received "DAQ Card 1 - PE Power(9)" update to on
2016-01-14 00:12:13.316 EasyDAQ Relay Card received "DAQ Card 1 - AUX Power(10)" update to off
2016-01-14 00:12:13.322 EasyDAQ Relay Card received "DAQ Card 1 - Shunt Patio Motion(11)" update to off
2016-01-14 00:12:13.326 Trigger DRM Vol Adjust (furnace OFF)
2016-01-14 00:12:13.330 EasyDAQ Relay Card received "DAQ Card 2 - Swing CAM 1(9)" update to off
2016-01-14 00:12:13.335 EasyDAQ Relay Card received "DAQ Card 2 - Swing CAM 0(10)" update to off
2016-01-14 00:12:13.337 EasyDAQ Relay Card received "DAQ Card 2 - Workbench Lamp (red-blk)" update to off
2016-01-14 00:12:13.340 EasyDAQ Relay Card received "DAQ Card 2 - Workbench Buzz (wht-grn)" update to off
2016-01-14 00:12:13.342 EasyDAQ Relay Card received "DAQ Card 2 - Switch 5vdc to PacRad Light (wht-grn)" update to on
2016-01-14 00:12:13.345 EasyDAQ Relay Card received "DAQ Card 2 - Future Attic" update to on
2016-01-14 00:12:13.348 EasyDAQ Relay Card received "DAQ Card 2 - DAS Output Switch(L)(15)" update to off
2016-01-14 00:12:13.349 EasyDAQ Relay Card received "DAQ Card 1 - Furnace Fan State(12)" update to on
2016-01-14 00:12:13.356 EasyDAQ Relay Card received "DAQ Card 1 - Alarm Bypass(13)" update to off
2016-01-14 00:12:13.363 EasyDAQ Relay Card received "DAQ Card 1 - Spare(HWpanel)(14)" update to off
2016-01-14 00:12:13.364 EasyDAQ Relay Card received "DAQ Card 1 - Spare(HWpanel)(15)" update to on
2016-01-14 00:12:13.366 EasyDAQ Relay Card received "DAQ Card 1 - HW Circ Pump State(16)" update to off
2016-01-14 00:12:13.372 EasyDAQ Relay Card received "DAQ Card 2 - DAS Output Switch(R)(16)" update to off
2016-01-14 00:12:13.379 Trigger Sonos Volume DRM
2016-01-14 00:12:13.388 EasyDAQ Relay Card received "DAQ Card 1 - Stairwell Motion State(17)" update to on
2016-01-14 00:12:13.390 EasyDAQ Relay Card received "DAQ Card 1 - Driveway Motion State(18)" update to on
2016-01-14 00:12:13.393 EasyDAQ Relay Card received "DAQ Card 1 - Garage Motion State(19)" update to on
2016-01-14 00:12:13.394 EasyDAQ Relay Card received "DAQ Card 1 - South Gate Motion State(20)" update to on
2016-01-14 00:12:13.396 EasyDAQ Relay Card received "DAQ Card 1 - Patio Motion State(21)" update to on
2016-01-14 00:12:13.398 EasyDAQ Relay Card received "DAQ Card 1 - Pool Sweep State(22)" update to on
2016-01-14 00:12:13.399 EasyDAQ Relay Card received "DAQ Card 1 - Axis S1 Output(23)" update to on
2016-01-14 00:12:13.401 EasyDAQ Relay Card received "DAQ Card 1 - don't use!" update to on
2016-01-14 00:12:13.403 EasyDAQ Relay Card received "DAQ Card 2 - Future 1" update to off
2016-01-14 00:12:13.404 EasyDAQ Relay Card received "DAQ Card 2 - Future 2" update to off
2016-01-14 00:12:13.405 EasyDAQ Relay Card received "DAQ Card 2 - Future 3" update to off
2016-01-14 00:12:13.405 EasyDAQ Relay Card received "DAQ Card 2 - Future 4" update to off
2016-01-14 00:12:13.406 EasyDAQ Relay Card received "DAQ Card 2 - Future 5" update to on
2016-01-14 00:12:13.407 EasyDAQ Relay Card received "DAQ Card 2 - Future 6" update to on
2016-01-14 00:12:13.408 EasyDAQ Relay Card received "DAQ Card 2 - Front Door Motion(23)" update to on
2016-01-14 00:12:13.408 EasyDAQ Relay Card received "DAQ Card 2 - Outside Air Temp Setpoint(24)" update to on
2016-01-14 00:12:20.481 EasyDAQ Relay Card sending "DAQ Card 1 - Back Buzz(4)" off
2016-01-14 00:12:23.306 EasyDAQ Relay Card sending "DAQ Card 1 - Back Buzz(4)" off
2016-01-14 00:12:26.921 EasyDAQ Relay Card sending "DAQ Card 1 - House Buzz(5)" off
2016-01-14 00:12:26.970 EasyDAQ Relay Card received "DAQ Card 1 - House Buzz(5)" update to off
2016-01-14 00:12:30.633 EasyDAQ Relay Card sending "DAQ Card 1 - Irrigation(6)" off
2016-01-14 00:12:30.682 EasyDAQ Relay Card received "DAQ Card 1 - Irrigation(6)" update to off
2016-01-14 00:12:33.839 EasyDAQ Relay Card sending "DAQ Card 1 - Spare(7)" off
2016-01-14 00:12:33.891 EasyDAQ Relay Card received "DAQ Card 1 - Spare(7)" update to off
2016-01-14 00:12:43.990 EasyDAQ Relay Card sending "DAQ Card 1 - Enable HW Circ(8)" off
2016-01-14 00:12:44.040 EasyDAQ Relay Card received "DAQ Card 1 - Enable HW Circ(8)" update to off
2016-01-14 00:12:44.073 EasyDAQ Relay Card received "DAQ Card 1 - HW Circ Pump State(16)" update to on
2016-01-14 00:12:48.352 EasyDAQ Relay Card sending "DAQ Card 1 - Pulse Garage Main(1)" off
2016-01-14 00:12:48.362 WebServer undefined page requested "http://glaciercam1.dyndns.tv:8176/apple-touch-icon-120x120-precomposed.png" from 192.168.0.8
2016-01-14 00:12:48.380 WebServer undefined page requested "http://glaciercam1.dyndns.tv:8176/apple-touch-icon-120x120.png" from 192.168.0.8
2016-01-14 00:12:48.403 EasyDAQ Relay Card received "DAQ Card 1 - Pulse Garage Main(1)" update to off
2016-01-14 00:12:52.086 EasyDAQ Relay Card sending "DAQ Card 1 - Pulse Garage Main(2)" off
2016-01-14 00:12:52.136 EasyDAQ Relay Card received "DAQ Card 1 - Pulse Garage Main(2)" update to off
2016-01-14 00:13:25.006 WebServer http://192.168.0.4:8000/++image?cameraNum=8 load error: HTTP Error 404: OK
2016-01-14 00:13:25.052 WebServer http://192.168.0.4:8000/++image?cameraNum=8 load error: HTTP Error 404: OK
2016-01-14 00:13:25.128 WebServer http://192.168.0.4:8000/++image?cameraNum=8 load error: HTTP Error 404: OK
2016-01-14 00:13:26.121 WebServer http://192.168.0.4:8000/++image?cameraNum=8 load error: HTTP Error 404: OK
2016-01-14 00:13:26.168 WebServer http://192.168.0.4:8000/++image?cameraNum=8 load error: HTTP Error 404: OK
2016-01-14 00:13:27.174 WebServer http://192.168.0.4:8000/++image?cameraNum=8 load error: HTTP Error 404: OK
2016-01-14 00:13:27.233 WebServer http://192.168.0.4:8000/++image?cameraNum=8 load error: HTTP Error 404: OK
2016-01-14 00:13:28.229 WebServer http://192.168.0.4:8000/++image?cameraNum=8 load error: HTTP Error 404: OK
2016-01-14 00:13:28.277 WebServer http://192.168.0.4:8000/++image?cameraNum=8 load error: HTTP Error 404: OK
2016-01-14 00:13:29.285 WebServer http://192.168.0.4:8000/++image?cameraNum=8 load error: HTTP Error 404: OK
2016-01-14 00:13:29.336 WebServer http://192.168.0.4:8000/++image?cameraNum=8 load error: HTTP Error 404: OK
2016-01-14 00:13:34.393 EasyDAQ Relay Card sending "DAQ Card 1 - Pulse Garage Main(2)" on
2016-01-14 00:13:34.443 EasyDAQ Relay Card received "DAQ Card 1 - Pulse Garage Main(2)" update to on
2016-01-14 00:13:35.037 EasyDAQ Relay Card sending "DAQ Card 1 - Pulse Garage Main(2)" off
2016-01-14 00:13:35.087 EasyDAQ Relay Card received "DAQ Card 1 - Pulse Garage Main(2)" update to off
2016-01-14 00:13:39.910 EasyDAQ Relay Card sending "DAQ Card 1 - Pulse Garage Main(1)" on
2016-01-14 00:13:39.959 EasyDAQ Relay Card received "DAQ Card 1 - Pulse Garage Main(1)" update to on
2016-01-14 00:13:40.918 EasyDAQ Relay Card sending "DAQ Card 1 - Pulse Garage Main(1)" off
2016-01-14 00:13:40.967 EasyDAQ Relay Card received "DAQ Card 1 - Pulse Garage Main(1)" update to off
2016-01-14 00:13:45.988 Trigger Garage Alarm 2 Pad LED Off
2016-01-14 00:13:45.990 DSC Alarm Alarm Zone 'DSC Z04 (garagemain2)' Closed.
2016-01-14 00:13:50.507 Schedule Garage Alarm 2 Pad LED Off (delayed action)
2016-01-14 00:13:50.894 Sent INSTEON "PowerLinc Interface" off (scene 53 - SwitchLinc 8_4)
2016-01-14 00:13:51.488 Trigger Garage Alarm 1 Watch OFF
2016-01-14 00:13:51.492 Trigger Garage Alarm 1 Pad LED Off
2016-01-14 00:13:51.494 DSC Alarm Alarm Zone 'DSC Z01 (garagemain1)' Closed.
2016-01-14 00:13:51.610 EasyDAQ Relay Card sending "DAQ Card 1 - Alarm Bypass(13)" off
2016-01-14 00:13:51.710 Sent INSTEON "Coffee Switch Manual/Reset" off (scene 53 cleanup)
2016-01-14 00:13:51.719 EasyDAQ Relay Card sending "DAQ Card 1 - House Buzz(5)" off
2016-01-14 00:13:52.413 Sent INSTEON "Lights, Dining Room" off
2016-01-14 00:13:52.861 Sent INSTEON "Lights, FamRm Ceiling" off
2016-01-14 00:13:52.941 Sent INSTEON "PowerLinc Interface" off (scene 51 - SwitchLinc 8_2)
2016-01-14 00:13:55.115 Sent INSTEON "Coffee Switch Manual/Reset" off (scene 51 cleanup)
2016-01-14 00:13:56.504 Schedule Garage Alarm 1 Watch OFF (delayed action)
2016-01-14 00:30:34.546 Application Indigo Cocoa client disconnected (192.168.0.206)
2016-01-14 01:42:47.983 Received INSTEON "T-Stat" temperature changed to 65.0
2016-01-14 01:45:00.786 Received INSTEON "T-Stat" temperature changed to 66.0
2016-01-14 01:49:26.152 Received INSTEON "T-Stat" temperature changed to 65.0
Sat Jan 23, 2016 12:13 pm
So the garage went up and the alarm went off, but it shouldn't have? How specifically do you have the Garage Alarm 2 Watch ON trigger defined?
I don't see anything in the error log that provides any clues. I suspect the EasyDAQ is just acting flakey (or there was a network hiccup that caused some bogus or corrupt commands to be received?).
Mon Jan 25, 2016 10:09 am
automatr offline
I've been having the same issues with the EasyDAQ network cards. The USB versions have been rock solid for years, without a single issue. I've been delighted with them. Based on this positive experience, and the fact that they were listed as supported by Indigo, I ordered several of the network versions. I was never able to get them to work. This has been such a disaster that I removed them from service. They are sitting in a box in my basement if anyone else wants to have a go at it. I've given up!
automatr
