Adding delays to get script to work
Fri Apr 29, 2022 4:56 am
boisy offline
Hi all,
I'm experimenting with Airfoil and the plug-in to get speech to text announcements going for my security system. The script below works, but with some caveats:
#!/usr/local/bin/indigo-host -x
from  AppKit import NSSpeechSynthesizer
import time
studyHomePodID = 86734491
airfoilPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.airfoilpro")
if airfoilPlugin.isEnabled():
   result = airfoilPlugin.executeAction("connect", deviceId=studyHomePodID, waitUntilDone=True)  # ID of Speaker device
   time.sleep(1.0) # Required or else audio comes through Mac speaker
text = "Hi"
nssp = NSSpeechSynthesizer
ve = nssp.alloc().init()
ve.setVoice_("com.apple.speech.synthesis.voice.samantha")
ve.startSpeakingString_(text)
while not ve.isSpeaking():
   time.sleep(0.1)
while ve.isSpeaking():
   time.sleep(0.1)
time.sleep(2.0) # Required or else no audio
result = airfoilPlugin.executeAction("disconnect", deviceId=studyHomePodID, waitUntilDone=True)  # ID of Speaker device
Note the two comments starting with 'Required or else'. It appears I need to force some delays in the code in order for the audio to propagate out to the HomePod speaker that I'm trying to play audio to.
Is this normal? I noticed the 'waitUntilDone' parameter of the executeAction is set to True, but delays are still necessary.
Just wondering if this is expected.
Fri Apr 29, 2022 7:22 am
Re: Adding delays to get script to work
Yeah that’s not surprising - even when you manually make adjustments in the airfoil UI it can take a second or two for it to negotiate the AirPlay speaker connections.
Fri Apr 29, 2022 10:54 am
boisy offline
Thanks for confirming, Jay. It's not a big deal, but I wanted to make sure it was expected.
Fri Apr 29, 2022 11:39 am
Their own remote speaker negotiation/connectivity used to be much faster than AirPlay, and I'm guessing that AirPlay 2 is even slower. Complexity has it's costs... ;)
BTW, you probably want to use self.sleep() (rather than time.sleep()) just in case the negotiation takes a long time or goes off the rails - it'll be easier for Indigo to kill it.
Fri Apr 29, 2022 2:16 pm
boisy offline
Thanks Jay. This code seems to work:
   indigo.activePlugin.sleep(0.1)
