Using Multiple Custom Devices in Actions.xml deviceFilter?
Mon Oct 08, 2012 11:17 am
nsheldon offline
I looked through the Indigo plugin developer documentation and couldn't find any way of specifying more than one custom device in the "deviceFilter" attribute of an action defined in the Actions.xml file. Is it possible, or do I have to create a custom dialog to select from a list of compatible devices. Here's an example of what I want to do.
   <Action id="zone1powerOn" deviceFilter="self.vsx1021k,self.vsx1122k">
      <Name>Power On (Zone 1)</Name>
      <CallbackMethod>zone1powerOn</CallbackMethod>
   </Action>
That doesn't work, however (using Indigo 5.1.6). While loading the plugin returns no errors, when that action is selected in an Indigo action, only the "vsx1122k" device type is listed in the Device menu. If it's not possible to AND multiple deviceTypeId values, is it possible to negate a specific deviceTypeId from the list? Is it possible to use a custom callback function so the plugin generates the list of devices rather than relying on Indigo to do that?
Tue Oct 09, 2012 2:28 pm
nsheldon offline
Re: Using Multiple Custom Devices in Actions.xml deviceFilte
This is the document I'm looking at. Should I be looking at a different document for Actions.xml configuration?
Tue Oct 09, 2012 3:24 pm
Improving this is definitely on our list, but currently you cannot specify more than one type. You can specify just "self" which will show all of that plugin's devices, but if you need finer control then you'll have to manually handle the device popup in the action ConfigUI (which isn't ideal especially if that is the only control).
Tue Oct 09, 2012 3:54 pm
nsheldon offline
Hey Matt. Thanks for the info. That's kind of what I figured. That will end up being a bit of a pain for the Pioneer Receiver plugin actions (of which there are many that will need their own ConfigUI dialog now). Is there a method that's called (to which plugin/Python developers have access), when the user either selects a device in the Indigo UI's plugin action dialog box (i.e. when Plugin is selected for the action Type, a Plugin is selected, an Action is selected under that, and then a Device is selected under that), or when the OK button is clicked on in a dialog box containing a Plugin action? Perhaps it could be overloaded to return an error if an incompatible device is selected?
Tue Oct 09, 2012 3:59 pm
Nope, the best you could do is show all of your plugin's devices then whenever the action is executed with a incompatible device have it write an error to the Event Log.
Tue Oct 09, 2012 4:12 pm
nsheldon offline
Okay. Thanks. I'll think about how best to proceed then. If it isn't already on the to-do/feature request list, I'd like to request the ability to either submit multiple custom devices in the deviceFilter attribute of an Actions.xml configuration, or add the option for a deviceFilterCallback (or similar callback) attribute so the plugin can return a filtered list to Indigo.
Wed Oct 10, 2012 6:53 am
Yep, it is definitely on our wish list.
