The source for as3Indigo and as3Indigo_explorer are available at the following github url:
https://github.com/mountainlabsI still need to create a build file for the two projects, but the basics are there. If you're a developer-type, you just need to add the as3Indigo library to the as3Indigo_explorer project and run the as3Indigo_explorer project (its an AIR application). I created these projects using IntellIj 11, so there is an iml file in the repo as well.
I have excluded any knowledge of control pages in this API, as this library is meant to replace them with custom flex user interfaces.
I have implemented the majority of the Socket API.
I have implemented the read portion of the RESTful API (can read objects from the server), but not the write (can't send commands to the server).
I will keep picking away at it when I have time. Let me know if you're interested in contributing!
Cheers!
Matt
