Python Path
Sat Jun 26, 2010 8:20 am
jocary offline
Python Path
I just turned on sql logging and I'm thinking about what to do with it. I have a little experience with python, burt for now I have one, probably naive, question. In the following code found in the web plugin, how does python find the module in the IndigoSqlClient directory?
from indigopy import indigoconn as ic
And if I wrote separate python code, not in a plugin, would I have to modify the $PYTHONPATH variable to find it?
Sat Jun 26, 2010 8:55 am
Re: Python Path
I believe this article will answer your question.
Sat Jun 26, 2010 7:55 pm
jocary offline
Re: Python Path
Thanks. I didn't mean to sound like I was asking inappropriately basic Python question here. The thing I was curious about was specifically how the web plugins can find the code in the sql client. It is not crucial now since I am using the sqlite3 module directly now, but I could imagine if an environment variable is being inherited by child processes, a python script to generate a report that is spawned by an indigo applescript might inherit that variable and find the code with the simple import statement.
Just curious.
Sat Jun 26, 2010 9:31 pm
Re: Python Path
Web plugins run in the Indigo Web Server process, which currently has it's own copy of indigopy. There currently is no including across the two processes.
You should know, however, that indigoconn isn't about the SQL database - it's about the connection between python and IndigoServer. For an example of a plugin that uses the database created by the IndigoSqlClient, check out the usageReporter in the file library.
...if an environment variable is being inherited by child processes...
If I'm understanding you, no, we aren't currently directly exposing Indigo objects to python scripts like how we expose objects in AppleScript. That may be part of the plugin API that we're developing for 5.0.
Sun Jun 27, 2010 12:34 pm
jocary offline
Re: Python Path
Occams razor strikes again!
Just for completeness, I wasn't thinking about Indigo objects being directly exposed. I was thinking more old school unix where the server would set the $PYTHONPATH environment variable and a child process, for example a python process spawned by an applescript triggered by something, would inherit the parents environment and be able to find the scripts.
But with that said, never mind.
