put inside images/devices
put inside images/static
put inside images/controls/devices
put inside images/controls/static
http://127.0.0.1:8176/images/controls/static/iPhone_button_hotter.png
jholcomb wrote:Matt, I had the same problem as user "thepainter" after install. When you go to edit the control page, the hotter and cooler button types are unspecified (as is the home icon). Setting Display to Static Image/Capture fixes the icon...
jholcomb wrote:But, did you specify a rule so that a single button can control both the heat and cool setpoints depending on the mode?
support wrote:jholcomb wrote:Matt, I had the same problem as user "thepainter" after install. When you go to edit the control page, the hotter and cooler button types are unspecified (as is the home icon). Setting Display to Static Image/Capture fixes the icon...
Ooops... I think I know what happened. My internal beta copy of Indigo has different internal values for those control types. Selecting Static Image / Caption from the Display menu item for those controls should fix them.jholcomb wrote:But, did you specify a rule so that a single button can control both the heat and cool setpoints depending on the mode?
The click action for those buttons should each have 2 actions in them. One changing the cool setpoint and the other changing the heat setpoint. So they both always change with a single click. Did the actions on those buttons drop off as well?
Regards,
Matt
