IndigoSqlClient -- logging changes to SQLite or PostgreSQL
Sat Jan 29, 2011 11:22 am
Re: IndigoSqlClient -- logging changes to SQLite or PostgreS
From the terminal try this:
/usr/bin/python -v
Then inside the python interpreter:
import sqlite3
And copy/paste the results (it will be a few dozen lines).
Next, from a new terminal window enter this:
/usr/bin/python
import sys
sys.path
And copy/paste the results.
Sat Jan 29, 2011 12:49 pm
hwalters offline
Thanks! It works fine now.
Here are the first results:
Last login: Fri Jan 28 12:00:01 on ttyp1
Welcome to Darwin!
henry-walters-mac-mini:~ henrywalters$ /usr/bin/python -v
# installing zipimport hook
import zipimport # builtin
# installed zipimport hook
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site.py
import site # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site.pyc
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/os.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/os.py
import os # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/os.pyc
import errno # builtin
import posix # builtin
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/posixpath.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/posixpath.py
import posixpath # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/posixpath.pyc
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/stat.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/stat.py
import stat # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/stat.pyc
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/genericpath.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/genericpath.py
import genericpath # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/genericpath.pyc
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/warnings.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/warnings.py
import warnings # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/warnings.pyc
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/linecache.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/linecache.py
import linecache # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/linecache.pyc
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/types.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/types.py
import types # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/types.pyc
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/UserDict.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/UserDict.py
import UserDict # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/UserDict.pyc
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/_abcoll.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/_abcoll.py
import _abcoll # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/_abcoll.pyc
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/abc.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/abc.py
import abc # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/abc.pyc
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/_weakrefset.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/_weakrefset.py
import _weakrefset # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/_weakrefset.pyc
import _weakref # builtin
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/copy_reg.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/copy_reg.py
import copy_reg # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/copy_reg.pyc
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/sysconfig.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/sysconfig.py
import sysconfig # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/sysconfig.pyc
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/re.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/re.py
import re # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/re.pyc
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/sre_compile.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/sre_compile.py
import sre_compile # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/sre_compile.pyc
import _sre # builtin
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/sre_parse.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/sre_parse.py
import sre_parse # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/sre_parse.pyc
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/sre_constants.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/sre_constants.py
import sre_constants # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/sre_constants.pyc
import encodings # directory /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/encodings
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/encodings/__init__.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/encodings/__init__.py
import encodings # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/encodings/__init__.pyc
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/codecs.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/codecs.py
import codecs # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/codecs.pyc
import _codecs # builtin
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/encodings/aliases.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/encodings/aliases.py
import encodings.aliases # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/encodings/aliases.pyc
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/encodings/ascii.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/encodings/ascii.py
import encodings.ascii # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/encodings/ascii.pyc
Python 2.7.1 (r271:86882M, Nov 30 2010, 09:39:13)
[GCC 4.0.1 (Apple Inc. build 5494)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
dlopen("/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/readline.so", 2);
import readline # dynamically loaded from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/readline.so
>>> import sqlite3
import sqlite3 # directory /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/sqlite3
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/sqlite3/__init__.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/sqlite3/__init__.py
import sqlite3 # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/sqlite3/__init__.pyc
# /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/sqlite3/dbapi2.pyc matches /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/sqlite3/dbapi2.py
import sqlite3.dbapi2 # precompiled from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/sqlite3/dbapi2.pyc
dlopen("/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/datetime.so", 2);
import datetime # dynamically loaded from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/datetime.so
dlopen("/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/time.so", 2);
import time # dynamically loaded from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/time.so
dlopen("/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_sqlite3.so", 2);
import _sqlite3 # dynamically loaded from /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_sqlite3.so
The second results:
Last login: Sat Jan 29 09:39:18 on ttyp1
Welcome to Darwin!
>>> import sys
>>> sys.path
['', '/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip', '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7', '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin', '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac', '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages', '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk', '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old', '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload', '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages']
I also reinstalled OS-X 10.4 and upgraded Indigo to the new version 4.1.16
Thanks again for the help!!
Hank Walters
