Get all values through REST API
Sat Jan 25, 2020 8:29 am
davinci offline
I want to use some variables and device states inside an html.
Of course I could just get all the individual values separately, but I think it makes sense to get them all at once - but only the ones I care (e.g. no type, but only value).
How can I do this?
What I imagine is something like this:
Response from calling REST API
LightKitchen:0
LightBasement:50
Door:false
ValueVariable:"test"
Like this I can set these variables in JavaScript and update them if needed. This will save me lots of traffic and time to get all values.
Alternatively how can I get only the value in the response?
/variables/isDaylight/value
Response:
true
Sat Jan 25, 2020 12:42 pm
Re: Get all values through REST API
That isn't current possible through Indigo's existing RESTful API. The wiki page has pretty much all of the current examples/capabilities documented. We have plans on a big overhaul of Indigo's Web Server which will include an improved RESTful API.
For cases where you have specific needs you might want to consider creating either a plugin, or executing an Indigo script periodically that writes out (to XML, etc.) the data you need. Both of those (plugin and script) would have complete access to Indigo's Python API which can quickly fetch the information you need.
Sat Jan 25, 2020 3:46 pm
davinci offline
Thanks, I will try the Python Script in that case. However , I use the reflector to access the data. I might be able to store all the values into one variable. Is there a limit to variable size?
Sat Jan 25, 2020 4:08 pm
I don't believe so but I'm not sure that large values have been stress tested. :roll: Let us know if you run into problems.
Sun Jan 26, 2020 2:44 am
davinci offline
Cool, no issues so far with over 9000 characters. :D
For reference, this would be the JS side - not sure if it already works with authentication: https://github.com/inorganik/digest-auth-request
Untested code
function updateIndigo() {
    var url = 'URL/variables/test.json';
    var getRequest = new digestAuthRequest('GET', url, USER, PWD);
    getRequest.request(function(data) {
      // success callback
                       var obj=data;
    },function(errorCode) {
      // error callback
        //var obj = JSON.parse( '{ "value": "John:1;Mike:2" }' );
        valueArray=obj.value;
        valueArray = valueArray.split(";");
        lengthArray = valueArray.length;
        var jsonText = {};
        for (var i = 0; i < lengthArray; i++) {
            variableArray = valueArray[i].split(":");
            setName = variableArray[0];
            setValue = variableArray[1];
            jsonText[setName] = setValue;
        alert(jsonText["John"]);
Now I need to tackle the Python side. Is it ok to write status every second in the variable or do you suggest to do it on demand? Would you use Schedule or just have one python script running forever?
I think it is more efficient to do it every second, since the variables might change more often than this. Hence a group trigger would trigger this too often.
The goal is to get this string:
LightKitchen:true;TemperatureKitchen:22.1;LightBasement:50
Something like this might be a start for variables:
bigVariable = ""
#Variables
id = [794830341, 794830341]
lengthArray = len(id)
for x in range(0, lengthArray):
    value = indigo.variables[id[x]].value
    name = indigo.variables[id[x]].name
    bigVariable = bigVariable + name + ':' + value +';'
#Switches
#Brightness devices
indigo.variable.updateValue(1603257068, bigVariable)
indigo.server.log(bigVariable)
The name ist the name of variable or the device. The value is either value or brightness, ...
How can I get all the ids for a specific device or variable?
Sun Jan 26, 2020 4:26 am
Trigger on a separate dedicated variable called ‘doRefresh’
When you visit your http page, use API to increment that variable so that the trigger fires and runs python script.
Sun Jan 26, 2020 9:36 am
davinci offline
Good idea to trigger like that. I have to test if this is fast enough though or if it triggers the old results.
Here is what I have so far. Unfortunately I get an error on virtual devices and real devices when accessing the value: KeyError: 'key id 170781720 not found in database'
Any ideas why this happens?
Second problem ü is not saved correctly...
bigVariable = ""
#Variables
id = []
for var in indigo.variables:
    if var.id != 1603257068: #this variable
        id.append(var.id)
#Switches
id = []
for var in indigo.devices:
    if var.enabled and u"onOffState" in var.states:
        id.append(var.id)
#Brightness devices
id = []
    if var.enabled and u"brightnessLevel" in var.states:
        id.append(var.id)
Sun Jan 26, 2020 12:06 pm
For your switches and brightness devices, you’re still accessing indigo.variables[].value - you’ve not changed it to indigo.devices[].value or the appropriate code thereof.
Sun Jan 26, 2020 12:48 pm
davinci offline
Good catch, thanks. It works now.
When accessing REST API over json "Umlaute" like äöü are not shown correctly. They are ok when not using .json.
I guess I will have to translate this in JS.
Sun Jan 26, 2020 5:50 pm
We'll look into that - it's likely a bug.
Mon Jan 27, 2020 11:45 am
Can you be more specific about this?
Mon Jan 27, 2020 11:54 am
davinci offline
I have a workaround for this:
        valueArray = valueArray.replace(/[\u00e4]/g, 'ä').replace(/[\u00F6]/g, 'ö').replace(/[\u00fc]/g, 'ü');
However, the authentication doesn't work...
Is this Indigo-related?
    var getRequest = new digestAuthRequest('GET', urlIndigo + "variables/UpdateIndigo.json", user, password);
                       var obj=data;
      // error callback
Mon Jan 27, 2020 11:57 am
davinci offline
When opening the json url in a browser I get B\u00fcro instead of Büro.
What I read about this ist, that this is a normal behavior for json, but there is a setting to change that..
Mon Jan 27, 2020 2:41 pm
                       var obj=data;
      // error callback
I have no idea what that JavaScript does as I'm not a JavaScript expert. The Python requests library, which supports Digest Authentication, works fine (as do all browsers and the curl command), so I'm guessing there's something going on in the JavaScript.
Mon Jan 27, 2020 2:42 pm
Yes - that's standard ASCII encoding for unicode characters. JavaScript should correctly convert those when converting JSON to JavaScript objects, though again since I'm not a JavaScript expert I don't know where to kick it to make it work.
