Using graphs with SQL Logger Plugin
Mon May 30, 2016 11:36 am
davinci offline
I want to get data from the Sqlite database, process the last 7 days (or 24h) of a sensor and put the values in a nice graph on a website. The data will be read locally by PHP.
I think Charts v3 might be a valid platform to show the data:
https://www.amcharts.com/demos/date-based-data/
Something like this works but it seems to be lot of work to program for every value of every sensor...
<?php
    $db = new SQLite3('test.sqlite');
    $db->busyTimeout(5000);
    $kitchen= ($db->querySingle('SELECT value FROM variable_history_4923453425 ORDER BY id DESC LIMIT 1'));
    $sleep = ($db->querySingle('SELECT value FROM variable_history_1564776538 ORDER BY id DESC LIMIT 1'));
    echo '
    var chartData = [
"raum": "sleep",
"temperatur": ' . $sleep . ',
"color": "#B0DE09"
"raum": "kitchen",
"temperatur": ' . $kitchen . ',
"color": "#BF3EFF"
    $db->close();
    unset($db);
Is there anything done already where I can build upon?
Or are there other ideas?
Tue May 31, 2016 5:52 am
Re: Using graphs with SQL Logger Plugin
It isn't PHP based (rather, an Indigo plugin), but have you tried Karl's INDIGOplotD?
