fcntl in py 2.6
Fri May 01, 2015 12:13 am
fcntl in py 2.6
In py 2.7 the attached test.py program reads the stream of data generated by pgm.py(*) nicely, but NOT when used under py2.6 (in plugin or standalone program)
python program is started with
/usr/bin/python2.6 test.py or ... python2.7 test.py
test.py:
import fcntl, os, subprocess, time
p = subprocess.Popen([pythonPath, '/xxx/yyy/pgm.py'], stdout = subprocess.PIPE, shell = False)
flags = fcntl.fcntl(p.stdout, fcntl.F_GETFL) # get current p.stdout flags
fcntl.fcntl(p.stdout, fcntl.F_SETFL, flags | os.O_NONBLOCK)
while True:
      time.sleep(1)
      print "hello"
      xx =  os.read(p.stdout.fileno(), 1024)
      if len(xx) > 5: print xx
   except OSError:
      time.sleep(5)
(*) pgm.py:
import time
while true:
  print "abc"
  sys.stdout.flush()
  time.sleep(3)
any advice?
thx
Fri May 01, 2015 3:52 am
Re: fcntl in py 2.6
Hi Karl,
I am not sure exactly what output you are expecting but in seems similar in python2.6 vs python2.7.
I had some difficulty exactly replicating your test. I had to make changes to pgm.py to get it working:
import time
import sys
while True:
  print "abc"
  sys.stdout.flush()
  time.sleep(3)
i.e. add import sys and change true to True
Also when running test.pgm, it couldn't find pythonPath so I set it to '/usr/bin/python2.6' and '/usr/bin/python2.7' before each test as appropriate. I added in a print statement to print out the value of the pythonPath variable as a double check. :)
The output I got from a 2.6 test was:
$ python2.6 test.py
pythonPath used for test: /usr/bin/python2.6
hello
hello
hello
abc
abc
hello
hello
abc
abc
hello
hello
hello
abc
abc
hello
hello
hello
abc
abc
hello
hello
abc
abc
hello
and the output from a 2.7 test was:
$ python2.7 test.py
pythonPath used for test: /usr/bin/python2.7
hello
hello
hello
abc
abc
hello
hello
abc
abc
hello
hello
hello
abc
abc
hello
hello
abc
abc
hello
hello
hello
abc
abc
hello
Does this help at all?
Fri May 01, 2015 8:21 am
Re: fcntl in py 2.6
I stripped down my real py program. :oops: .
and when I actually do it very simple it actually works. thanks for debugging, ...
now I have to step by step add back functionality.
