turtle
Thu Sep 11, 2014 7:19 pm
turtle
can I use python turtle in indigo?
in idle it works, when I open a scripting shell window within indigo
import turtle
def draw_square():
window = turtle.Screen()
it complains that
'module' object has no attribute 'Screen'
How do I add the Screen method to indigo? Do I need to import another library?
thx
Thu Sep 11, 2014 7:31 pm
Re: turtle
What are you trying to draw to? Indigo Server has no UI so there's no "window" to draw to.
Thu Sep 11, 2014 7:54 pm
Re: turtle
know that,... essentially would like to create dynamically png files using a graphics package that runs under py 2.5
get the same error in a regular terminal / py session, has nothing to do with indigo I guess.
Thu Sep 11, 2014 8:08 pm
Re: turtle
Thu Sep 11, 2014 8:13 pm
Re: turtle
I'm not sure if it is possible to get it working, but it definitely is failing because of python 2.5. If you try it from Terminal after launching "python2.5" then it fails in the same manner as from Indigo's scripting shell.
Thu Sep 11, 2014 8:17 pm
Re: turtle
I think the Turtle library assumes an interactive session, like IDLE. Using a straight drawing package would be better.
Thu Sep 11, 2014 9:47 pm
Re: turtle
installed cairo (after many trials with home-brew.) now have to make py recognize it.
Thu Sep 11, 2014 10:01 pm
Re: turtle
pycairo:
Dependencies
cairo >= 1.8.8
Python >= 2.6
no luck with py 2.5
