Mac OS X CM11 USB Driver available
Fri Aug 12, 2005 8:24 am
lougoni offline
:D
For the interested ones. I've found a location with USB driver software for the CM11.
The explanation:
http://www.mancave.co.uk/2005/05/17/1116363475290.html
The download location:
http://tech.prolific.com.tw/visitor/fca ... d=33993428
Fri Aug 12, 2005 11:36 am
Re: Mac OS X CM11 USB Driver available
Great, thanks for the info. Sounds like that driver might just work out, which would be great since it'll save some money compared to getting a Keyspan adapter.
Regards,
Matt
Sun Dec 04, 2005 2:49 am
kenjon offline
And then?
I am totaly new to X10.
I installed Indigo, got a CM11 USB. Downloaded and installed the driver mentioned below. But how do I set Indigo to use it? What interface should I choose in Indigo....?
Sun Dec 04, 2005 9:12 am
Re: And then?
After you install the driver and reboot, run Indigo and choose the CM11 interface. The CM11 you have is really a serial interface with a USB to serial adapter cable. You should then see some options in the serial port menu, one of which corresponds to the adapter driver. Not sure what it will be called, but it will NOT be anything like "internal modem", or "bluetooth adapter."
Regards,
Matt
Wed Dec 21, 2005 1:17 am
Jean offline
Link Dead
I am trying to get hold of this driver but linkk seems to be dead
Any ideas ?
If driver is small can somebody be kind enough to email it to me : jrlyon@wanadoo.fr
Jean
jean
Tue Apr 18, 2006 1:46 am
KrazyKiwi offline
(No subject)
Ok, FWIW, here's where the PL-2303 (usb-to-serial) driver is at:
http://www.prolific.com.tw/eng/downloads.asp?ID=31
For MacOS X, you need the one called "md_pl2303H_HX_X_dmg_v1.1.0b1.zip"
(driver's for 'doze, OS 8/9, and Redhat linux are also there)
No guarantees, it'll still be there, or have the same filename by the time you have a go at snaffling it! :wink:
Tue Apr 18, 2006 9:26 pm
(No subject)
Thanks for the download link!
Matt
Fri Apr 21, 2006 1:54 pm
macpro offline
(No subject)
Keep in mind that this driver is for PowerPC Macs only.
A version for intel Macs is still not available.
I've sent an e-mail to Prolific to ask about availability about 3 weeks ago, but still haven't received an answer.
Wed May 24, 2006 11:47 pm
macpro offline
(No subject)
Prolific has posted an updated driver that should work on intel Macs.
You can find it at the link mentioned above.
Wed Jul 05, 2006 7:00 am
Lalit offline
Need driver for CM-11 USB
Hi !
I need the driver for CM-11 USB from Prolific.
The problem is that the site is currently unavailaible ! Arrrrgh !
Please, can someone send me the driver on : mistalalit@yahoo.fr
Thanks in advance !
Wed Jul 05, 2006 7:08 am
macpro offline
(No subject)
You have mail...
Wed Jul 05, 2006 8:27 am
Lalit offline
(No subject)
macpro wrote:
You have mail...
Meanwhile I was waiting for an answer, I received my 2,4m x 1,35m electrical screen for my video projector ! And when I get back on my computer I saw your mail !
So many joy in a few minutes...
The driver works perfectly !
Thank you so much for your quick answer MacPro !
Fri Nov 10, 2006 6:10 pm
panxon offline
I need the Intel version of the drivers
The link at prolific seems dead. COuld anyone send me please the intel based Mac drivers for the CM11.
Thanks a lot
panxon at mac.com
Fri Nov 10, 2006 7:37 pm
macpro offline
(No subject)
You have mail...
