Interpreting RF signals to triggers - Keychain Remote
Fri Dec 17, 2021 8:25 am
roberthuttinger offline
Hello friends!
I do recall back in the day I was able to get the command from my keychain xc-10 remote (similar to, if not this; https://www.amazon.com/X10-Security-Keyfob-Remote-USA/dp/B01N4F75N4)
I am getting the signals transmitted via RF interface.W800USB When pressed I get the appropriate commands received from the top four buttons
  Received RF                     security command disarm (ID 190)
However in the devices for triggers the best I can get is for a trigger to get that a generic signal was sent. This means I can toggle a boolean state true/false when any of the four keys is pressed. Id like to set up separate triggers for not only each specific key, but potentially different keys on a separate remote as well... but let's start with the one for now.
I dont recall if I used to have an applescript to read the logs to parse the info, I don't remember how to do that anymore... it has been years since my system was nuked and the backup drive also died!
I have downloaded the SDK kit and installed all the drivers but nothing seems to get me where I need to be.
I have tried adding devices using all the remote 'types'. eg: Remote Button - SlimFire KR19A but the remote doesnt have an 'address'
I have read several variations on instruction about registering such as holding the top two button, nothing... These are circa 2014.
I am getting codes/signals received, Now what?
Question:
Is it possible to parse these appropriately?
Stuff
OS: 10.6.8
Version: Indigo 6
Cheers!
Screen shot 2021-12-17 at 9.23.23 AM.png (82.57 KiB) Viewed 1655 times
Screen shot 2021-12-17 at 9.22.51 AM.png (34.14 KiB) Viewed 1655 times
Fri Dec 17, 2021 9:49 am
Re: Interpreting RF signals to triggers - Keychain Remote
The 3rd party Switchboard plugin used to be able to catch those signals. I don't know if it still works or not but you should give it a go.
Fri Dec 17, 2021 11:03 am
thanks for the assist friend!
I believe thats what used to work, but it doesn't seem to add those options in the `conditions` tab of the `triggers` setup.
Ill nuke and reload from scratch and see whats what.
thanks!
Mon Dec 20, 2021 10:31 am
Re: RF signals to triggers - Keychain Remote (Switchboard)
It turns out Switchboard will work as I remember it did. I'm going to offer my steps to success for posterity!
OK... WHEW! Noa that's over with lets get to the meat 'n' taters precious.
  • Install the drivers if not already installed.
  • Install or get your interface working. In my case the `interface type` was not the default under Indigo6 > Interfaces >X10RF
  • Switch the port if necessary and under preferences select the `Serial Port` (ie: usbserial-A4007TsS )
  • Once this is up and running I installed a fresh battery and pushed a button and got this signal in the event log (⌘8)
PICTURE1 - Event Log
Screen shot 2021-12-20 at 11.00.46 AM.png (19.43 KiB) Viewed 1561 times
  • Now we need to create a device under view > devices (⌘1)
  • Name: Remote1, Type: Switchboard, Model: X10 Monitored Device, Address: 190 (using the ID provided in event log above)
PICTURE2 - Device Settings
Screen shot 2021-12-20 at 11.09.26 AM.png (75.34 KiB) Viewed 1561 times
  • Here is where I was trying to create a trigger, we don't!
  • Create another device, in this case I called it `Remote`
PICTURE3 - Device Group
Screen shot 2021-12-20 at 11.12.16 AM.png (76.74 KiB) Viewed 1561 times
  • Name: Remote, Type: Switchboard, Model: X10 Monitored Device Group, Address: undefined
  • under edit device settings:
  • Add the device in the previous step to: Registered Devices for this Zone
  • Check the box in the third pane: Turn on Timed Device Support
  • Now we go to: Action Groups (⌘4)
  • Note at this point if there is no action Group and you push a button, you get a helpful hint (ie: Unable to find the Action Group for this Group: [Remote_LightsOff])
  • In this case the event log is telling you what you need to create and Action Group for!
  • Create a new Action Group named: Remote_LightsOff
  • Then Remote_LightsOff (the same variable name given in the event log)
PICTURE4 - Action Group
Screen shot 2021-12-20 at 11.21.29 AM.png (19.78 KiB) Viewed 1561 times
  • Don't forget to reload the plugin, or restart Indigo!
  • Have a beer! (or whatever your drink of choice is)
Thanks a ton to Ben Schollnick, and please donate to your developers, they do what they love and we should all be rewarded for bringing solutions to communities!
