X10 & HomeKit ?
Mon Nov 09, 2020 8:48 am
rlesperance offline
X10 & HomeKit ?
Is there a bridge in Indigo between X10 and HomeKit ?
Mon Nov 09, 2020 9:36 am
Re: X10 & HomeKit ?
In what direction? You can publish X10 devices for HomeKit control using the HomeKit Bridge plugin.
Mon Nov 09, 2020 10:06 am
rlesperance offline
Re: X10 & HomeKit ?
Thanks for the info.
I am a HomeKit newbie. My question was to find a way to integrate Indigo or X10 to HomeKit. I will give a look to that bridge.
Tue Nov 10, 2020 8:37 am
Different Computers offline
Re: X10 & HomeKit ?
Ha! HomeKit Bridge is exactly what you want. It does anything you might need.
Sat Nov 28, 2020 11:50 am
rlesperance offline
Re: X10 & HomeKit ?
Great !
I installed and activated the HomeKit bridge in Indigo on my iMac.
Since I am with Catalina, I have to use the Home app on iOS. What do I do next to be able to use the Home app with Indigo ?
Sat Nov 28, 2020 12:13 pm
siclark offline
Re: X10 & HomeKit ?
Could you describe what you mean?
The homekit bridge is one way, ie makes indigo devices show in Home app iniOS. You can't access other homekit devices in indigo with it.
Sat Nov 28, 2020 12:19 pm
rlesperance offline
Re: X10 & HomeKit ?
That's what I understand.
The HKB is installed on my iMac and activated in Indigo .... but I don't see any Indigo devices in my Home (Maison) app on my iOS device.
What am I missing ?
Sat Nov 28, 2020 12:30 pm
Re: X10 & HomeKit ?
Did you publish any of your devices using the plugin?
Sat Nov 28, 2020 12:32 pm
rlesperance offline
Re: X10 & HomeKit ?
No :( ....How do I do that ?
Sat Nov 28, 2020 12:34 pm
Re: X10 & HomeKit ?
Create an Accessory Server (HKB plugin device type), then add other Indigo devices to that.
Sat Nov 28, 2020 12:35 pm
siclark offline
Re: X10 & HomeKit ?
Then you need to add a new accessory in the Home iOS app using the code shown in the HKB Device you create.
Sat Nov 28, 2020 12:56 pm
rlesperance offline
Re: X10 & HomeKit ?
Not quite as user friendly as a Mac ... but I am getting further.
What do I do with this error message ... sorry it's in French:
Error HKB.jpg (33.88 KiB) Viewed 6892 times
Sat Nov 28, 2020 1:03 pm
siclark offline
Re: X10 & HomeKit ?
You need to accept it, possibly in the security section of preferences.
Sat Nov 28, 2020 2:59 pm
rlesperance offline
Re: X10 & HomeKit ?
Found no way in System Preferences to autorize the EPS HomeKit Bridge.indigoPlugin item.
Sat Nov 28, 2020 3:25 pm
Re: X10 & HomeKit ?
Have you tried adding the indigo components to the quarantine list? I’ll have a look see if I can find the command
