Indigo log error ...
Fri Jan 31, 2020 8:13 am
rlesperance offline
Can somebody help me with the error messages found in my Indigo logs ? Where do they come from and what do they mean ?
See files here.
Thanks in advance.
Robert Lespérance
Fri Jan 31, 2020 9:14 am
Re: Indigo log error ...
Those are errors coming from the CM11 USB to serial driver. Could be a bad USB cable or failing hardware, or a USB conflict. Try different USB ports (and cables if you have any that match).
Sat Feb 01, 2020 12:13 pm
rlesperance offline
Hello Matt,
The possibles culprits:
• USB port of my iMac (that's easy to try out)
• Keyspan adapter ?
• serial cable to CM11A ?
• CM11A interface (this is a new one)
What is to most probable one ?
Sat Feb 01, 2020 1:49 pm
Really could be any of them I'm afraid.
Could also be a driver problem/bug if you've upgraded your macOS version recently. In that case make sure you have the most recent driver installed for your USB to serial adapter.
