current best support option for ds10a and ms10a
Thu May 17, 2018 8:44 am
WagnerOne offline
I am wondering what is the best option for supporting the x10 ds10a door sensor and x10 ms10a motion sensor devices.
Right now I continue to use an AppleScript attachment named "ds10a security.scpt" by Benjamin Schollnick, which gets the job done for the ds10a just fine. I have a stack of ms10a devices I don't currently have a means of using. However, I know AppleScript is being deprecated, and I'm wondering if I should be proactively looking toward a different solution to support these devices.
I do use a lot of x10 ms16a motion sensors that are natively supported in Indigo. I interact with those via a W800RF32. They work fine, but since I have a bunch of idle ms10a devices, it'd be nice to use them too.
It looks like Benjamin's later effort, Switchboard, might be the ticket. I read, while it was last updated to work with Indigo v5, it continues to work and be used in current Indigo 7. I guess I'm just looking for opinions to best support the ds10a and ms10a other than "replace the inexpensive, perfectly good, low profile, and reliable x10 devices with something expensive" - I know that's an option. :wink:
Thanks for any/all feedback!
Mike
Fri May 18, 2018 10:28 am
Re: current best support option for ds10a and ms10a
That sentence is full of YOUR MILEAGE MAY VARY statements... ;)
I suspect that the Switchboard plugin will be your best bet.
[MODERATOR NOTE] moved to the correct forum.
Fri May 18, 2018 11:40 am
WagnerOne offline
I suppose I should emphasis that statement was exclusively directed at the ds10a and the W800RF32. :D
Can I claim I'm not really using x10 since I'm only using the RF capabilities of the x10 sensors?? :|
Mon Jan 21, 2019 9:29 am
captcurrent offline
jumping in a bit late, but switchboard works well for me. I have multiple ds10a and ms10a
