[ANSWERED]X10 RF coupler
Tue Aug 05, 2014 2:09 pm
Mirus offline
Any chance any Insteon device will pick up an x10 RF signal? I have a bunch of x10 remotes I'd like to use. Or am I stuck trying to find my old x10 RF transceiver?
Insteon remotes are so dang expensive.
Tue Aug 05, 2014 3:33 pm
Re: X10 RF coupler
Nothing that's easy-to-use or particularly reliable. If you're really set on using X10 remotes, I'd get a W800USB which is quite reliable and has good reception range.
Wed Aug 06, 2014 9:41 am
Re: X10 RF coupler
Or a rfxcom trx/rec433 device which can pick up x10 and various other signal types (eg Oregon weather sensors)
Wed Aug 06, 2014 12:31 pm
ckeyes888 offline
Re: X10 RF coupler
+1 on the W800USB. I extended it's range dramatically by finding the right antenna placement.
I've tried all types of hard button remotes but always come back to the simple X10 PalmPad's.
They're small, cheap, can be labeled and have 18 programmable buttons, (counting the dim and bright).
Carl
Thu Aug 07, 2014 2:03 am
b_weijenberg offline
Re: [ANSWERED]X10 RF coupler
durosity:
The US X10 operates at 310MHz and can only be received by the RFXtrx315.
The European X10 operates at 433.92MHz and can be received by the RFXtrx433(E) and RFXrec433.
Sat Aug 09, 2014 3:44 pm
Ah well that would make the difference.. :)
