[ANSWERED] PowerLinc 2413U interface not seeing X10 Events
Tue Apr 22, 2014 2:25 pm
rlust offline
Up till a couple of weeks ago my 2413 saw X10 events that I used to trigger events. Has anyone else seen this or do you have any ideas on what would cause this?
I can send X10 events and they work but I never see other sent X10 events.
Thanks for any help!
Wed Apr 23, 2014 7:18 am
Re: PowerLinc 2413U interface not seeing X10 Events
There have been a couple reported cases of X10 receiving and/or transmitting ceasing to work on the 2413U (most of the time INSTEON continues to work fine). I'd try plugging the 2413U into the same circuit/outlet as one of your X10 transmitters (tip: use an extension cord) to better rule out a signal problem. If that doesn't show up in the Event Log then I think it has malfunctioned.
Fri Apr 25, 2014 6:08 am
rlust offline
Re: [ANSWERED] PowerLinc 2413U interface not seeing X10 Even
If I need to replace the 2413U what is the best option?
Fri Apr 25, 2014 8:12 am
The 2413U is still our recommended INSTEON controller (overall they have proven to be reliable). I'd try to get it swapped out, presuming you bought it within the last 2 years.
For Z-Wave modules we recommend the Z-Stick Series 2.
Fri Jul 04, 2014 12:55 am
thumpinc offline
I have had this happen twice now. I replaced the first 2413U unit which stopped receiving x10 within 3 months of installation and this one has worked for about six months before also losing all X10 reception.
I wish I didn't need to see X10 but my problem is that we have a whole house VISONIC security system that sends out x10 signals and I capture those for motion and door openings/closings so really need that X10 connectivity. But replacing these doohickeys is expensive if it is twice a year...
Fri Jul 04, 2014 8:13 am
They have a 2 year warranty so you shouldn't be paying for replacements. I know the Indigo Store will replace them via warranty if that's where you bought it originally.
Fri Jul 04, 2014 11:00 am
thumpinc offline
The 2413U stopped receiving X10 and I tried EVERYTHING. I reset PRAM in case the USB connection somehow locked up. I reset the 2413U and resynced all the links. I unplugged it and the X10 transceiver from power and the 2413U from USB and 'let them rest'. I restarted the server software, shut down and restarted the machine, and nothing worked. I spent hours. I then ordered a replacement from Amazon and was going to call it a day.
Ok. So here is the weird part :
After I gave up and was walking out of the office I double-tapped the INSTEON dimmer in there to turn off all the lights in the office - it causes a trigger that then shuts down the various INSTEON and X10 devices in the room. To my surprise, after it did that I started hearing the various DINGS associated from receiving X10 signals from various motion detectors coming from the server. I looked in the log and sure enough all of a sudden a FLOOD of X10 signals hit all at the same time - right after the trigger that shuts down the office ran. Now, everything is back to normal.
I'm utterly confused - though everything is working again. Any thoughts on why this would be happening?
To note - the insteon dimmer I double tapped is a two wire dimmer, should that make a difference.
Fri Jul 04, 2014 12:14 pm
I think it's just a bad 2413U - something is causing the X10 part of the interface to not work consistently.
