[ANSWERED]X 10 CM 15A
Sun Apr 13, 2014 10:31 am
Re: [ANSWERED]X 10 CM 15A
Pacman1840 wrote:
Will Indigo permit me to set more than one action for the same device on the same day, just a different time? If so, how should I enter it?
I may not be understanding your question - but you can have as many schedules as you like. Just create a new schedule for the specified date/time. I think you might want to read through the Indigo Overview document - it will explain the major parts of Indigo and I suspect it will answer a lot of questions you may have.
Fri Aug 15, 2014 7:03 am
Pacman1840 offline
I have been very pleased with the performance of Indogo 6 until yesterday. Apparantly my X 10 interface failed and is no longer connected/activated causing my scheduled actions not to work. Please tell me how I can reset/reactivate. Also, I notice that the red "CM 15A in the lower left of my screen now has a line drawn thru it.
Paul
Fri Aug 15, 2014 9:39 am
The red/line means that Indigo can't talk to the CM15A. I think the only way to reset a CM15 is to unplug and remove the batteries. Let it sit that way for a few minutes then plug it back in. Then try to enable it in Indigo and see if it finds it. Are there any errors in the Event Log when you try to enable it?
Sat Aug 16, 2014 4:45 am
Pacman1840 offline
Thanks to everyone for your posts, my Indigo 6 is now working fine. Have a good weekend.
Pacman1840
Mon Nov 02, 2015 3:38 pm
Hans Kiesewetter offline
unplug, battery removal and plug in worked for me too! thanks :D
(had this issue after update to version 6.1.4,
Did an update to OS X El Capitan the day before)
