Weird log items ...
Wed May 31, 2017 4:11 am
rlesperance offline
Weird log items ...
Hello,
I just realized that there has been some weird events that were logged in Indigo in the last few days. You can find them here.
Can you help.
Regards.
Wed May 31, 2017 9:04 am
Re: Weird log items ...
2017-05-31 05:21:14.817 Error undefined byte (64) from interface
2017-05-31 05:21:14.818 Error CM11 communication stalled -- resetting to idle state
2017-05-31 05:21:15.219 Error undefined byte (00) from interface
2017-05-31 05:21:15.220 Error CM11 communication stalled -- resetting to idle state
Those could indicate one of the following:
  1. Powerline noise
  2. Failing CM11 interface
  3. A failing USB to serial converter
  4. A USB driver issue with the USB to serial converter
If you're seeing X10 traffic for devices that don't exist in your system, then it could also be a failing X10 device that's spewing lots of garbage on the power line and that's causing the noise in #1. Check out the signal troubleshooting page for suggestions on how to diagnose.
