equivalent to "Set Virtual On/Off Device State" via python
Fri Feb 12, 2021 6:05 pm
tcherna offline
I'm wondering if there is a way to script setting the device state to on or off via a python script (Server Actions->Script and File Actions) vs Device Actions->Virtual Device Controls
Sat Feb 13, 2021 1:31 am
neilk offline
Re: equivalent to "Set Virtual On/Off Device State" via pyth
Take a look at https://wiki.indigodomo.com/doku.php?id=indigo_6_documentation:plugin_scripting_tutorial that should point you in the right direction, with the first example.
Sat Feb 13, 2021 12:40 pm
tcherna offline
Right, but that page talks about how to turn the device on, which I think is different then setting the internal state of the virtual device (otherwise why would there be a special command for it). Specifically, calling the on method would activate the on action group, but setting its internal state does not. This would be the shortcut to setting the variable, if I was using a status variable.
Sat Feb 13, 2021 1:03 pm
You can script the UI action to set a Virtual Device state. And, no, you aren't crazy, I realized that it was missing from the docs to I just added it... ;)
Sat Feb 13, 2021 1:09 pm
tcherna offline
There is an extra & in the link ;)
Sat Feb 13, 2021 1:17 pm
tcherna offline
Thanks Jay. A follow up question. Is it more efficient to create a virtual device with a named variable, or an implicit one (and use the above scripting to set it)?
Sat Feb 13, 2021 1:34 pm
Fixed, thanks for the heads up.
I suppose using the action (via UI or script) is maybe slightly more efficient since we wouldn't have to process variable changes, but the plugin is already receiving all variable updates anyway so the actual processing is negligible.
