Virtual Sprinkler Schedule Issue...
Sat Jun 20, 2020 7:46 pm
jheddings offline
While working on a sprinkler master device (dubbed Sprinkler Buddy), I realized that there is an existing Sprinkler Group in Virtual Devices :oops:
However, when using a virtual Sprinkler Group, it appears the the schedules are limited to showing 16 zones only, so I'm unable to create a "master schedule" that spans multiple controllers.
In this image, you can see the virtual group configured in Indigo:
Screen Shot 2020-06-20 at 7.36.36 PM.png (67.92 KiB) Viewed 2727 times
However in this image, you can see that the schedule stops after controller A:
Screen Shot 2020-06-20 at 7.35.51 PM.png (32.18 KiB) Viewed 2727 times
Any ideas how to resolve this?
FWIW, I ran into the same issue on my Sprinkler Buddy plugin attempt, which is what caused me to go poking around. If you are interested in how far I was able to get, the code is posted here: https://github.com/jheddings/indigo-sprinklers
Sat Jun 20, 2020 9:13 pm
jheddings offline
Re: Virtual Sprinkler Schedule Issue...
As a quick follow up, just wanted to point out that the UI controls show all zones from both Rachio controllers.
Screen Shot 2020-06-20 at 9.12.27 PM.png (327.78 KiB) Viewed 2713 times
Sun Jun 21, 2020 5:43 pm
This looks like a bug / limitation in the current version of Indigo. I'll look into getting it to show up to 32 zones in that UI.
Sun Jun 21, 2020 9:37 pm
jheddings offline
Thanks, Matt!
Wed Dec 23, 2020 3:14 pm
Indigo 7.5 is now available and should fix this UI issue.
Tue Apr 06, 2021 9:42 pm
jheddings offline
Thanks, Matt!!
The devices do show up now, but the names are a little short for the UI. Especially with the controller name prepended, some of the zones can be hard to read.
I can count them out as a workaround, just wanted to point it out in case there is a patch coming.
Screen Shot 2021-04-06 at 9.40.02 PM.png (64.69 KiB) Viewed 2266 times
Wed Apr 07, 2021 3:57 pm
Yes, thanks for the screenshot. That UI is kind-of a big mess to be honest. It needs a serious makeover.
