Virtual device for dimmers, to make a 3-way dimmer?
Sun Nov 01, 2015 11:34 pm
webdeck offline
My house came with a number of switches configured as 3-way circuits. I've replicated it as best I can with Insteon dimmer switches. The switches are linked to each other so that when one is turned on, the other mirrors it. I have one of the switches hidden in the UI so that I don't see 2 switches for the same light. The issue is, if I want to adjust the light through Indigo, then the hidden switch doesn't update its state to reflect the light. I tried using a virtual device for this, but that acts like an on/off switch, not a dimmer.
Is there a simple way to create a virtual dimmer that keeps the two switches in synch with each other?
-Mike
Mon Nov 02, 2015 12:35 pm
Re: Virtual device for dimmers, to make a 3-way dimmer?
You don't need a virtual device - just create a trigger such that when the one that's visible in Indigo has any change it then triggers a Match Brightness action for each of the other lights. See this wiki article for details.
Mon Nov 02, 2015 10:58 pm
webdeck offline
Thanks for the quick reply - I'll give that a try.
-Mike
Sat Nov 14, 2015 4:18 pm
webdeck offline
Just a quick note that I got that to work for everything but a FanLinc, as I don't think the FanLincs support AppleScript to get the speed of the fan in order to update keypad button lights. I posted that question in a separate thread here: http://forums.indigodomo.com/viewtopic.php?f=78&t=15055
-Mike
Mon Nov 16, 2015 12:02 pm
No need for AppleScript (or, for that matter, any script). See the KeypadLinc & FanLinc article for details.
Mon Nov 16, 2015 11:45 pm
webdeck offline
Thanks. Got it working.
-Mike
