Enhance or suppress "Embedded script executor host1 started"
Tue Jun 13, 2023 7:44 am
ryanbuckner offline
I have lots of these entries into the logs. They don't contain enough information to be useful, so I'd like to enhance them with more information or suppress them:
Jun 13, 2023 at 9:08:00 AM
Jun 13, 2023 at 9:10:00 AM
Jun 13, 2023 at 9:33:01 AM
Jun 13, 2023 at 9:38:00 AM
Tue Jun 13, 2023 2:25 pm
Re: Enhance or suppress "Embedded script executor host1 star
That can happen when you press the Compile or Execute buttons in the UI to run an embedded Python script. They can just be ignored (but there isn't a preference to disable the logging of them).
Wed Jun 14, 2023 9:15 am
ryanbuckner offline
I see them in the log when I haven't been using the UI in a while. For example, this was logged 2 minutes ago and I wasn't near my machine:
Jun 14, 2023 at 11:13:00 AM Embedded script executor host1 started
Wed Jun 14, 2023 6:11 pm
I think I had it backwards. There are 2 different embedded script executors: one for when the compile/execute UI buttons are hit, and one for executing embedded scripts from the Indigo Server engine (as part of schedules, triggers, etc.). The one you are seeing is the latter. It should just startup once and be reused. If you are seeing the message multiple times then you probably have embedded scripts that are taking more than 10 seconds to complete (which should be logged) in which case Indigo Server kills the process and starts a new one (the next time an embedded script needs to execute).
Wed Jun 14, 2023 6:58 pm
ryanbuckner offline
Thanks Matt. Looks like I have some stuff to troubleshoot.
