Konnected.io wire alarm interface
Fri Jun 14, 2019 7:14 am
henkjanvries offline
Has anyone ever played with this, im curious if i can use this together with Indigo and an already installed alarm in a new house i bought.
I do really want to migrate to hubitat or openhab to get this working.
Secondly replacing it with something that does integrate is off course exspensinve and time consuming.
Can we see if there can be a connections set up with the guys of Konnected?
Fri Jun 14, 2019 7:51 am
Re: Konnected.io wire alarm interface
What's the system you're starting with?
Fri Jun 28, 2019 9:35 am
Sorry just read your reply. I DONT want to migrate. Im using a honywell galaxy 16+ alarm system, this konnected board would fit it, and it would be great to have controles over it and the alarm in indigo
Fri Jun 28, 2019 9:50 am
The first step is to see if the konnected.io product is compatible with your alarm system. You should contact them for info on that.
If it is, then it's worth looking into interfacing it with Indigo. That is almost certainly going to require a plugin to be developed. They do publish an API, and some sample code, so it's certainly doable. Finding a developer that's interested would be the hard part.
