Right click to display Device print in a separate window
Sun Feb 24, 2019 6:41 am
This is a developer request with would help the development process.
This may have been requested before?
It would be extremely useful to be able to right click on an Indigo device in the main device list pane and select a new menu entry: Display device (or similar) that would display in a separate window the equivalent of e.g. :
indigo.server.log(u'\nDEVICE:\n{}'.format(dev))
At the moment you have to perform a number of clicks and pastes into a scripting Shell terminal window and the output then gets printed to the Indigo Event Log with then scrolls out of sight. So you then have to select the output and paste it into a text editor; all doable but long winded! :wink:
Sun Feb 24, 2019 10:12 am
Re: Right click to display Device print in a separate window
The Mutlitool plugin can reduce the number of steps. From the plugin menu, select the "Object Dictionary..." tool which then displays a config dialog for you to select the class of object (dev, var, etc.) and then the second menu item for the object. It will print the entire object to the events log.
Screen Shot 2019-02-24 at 10.09.11 AM.png (55.86 KiB) Viewed 887 times
   Multitool                       ============================== Parlor - TiVo Dict ==============================
   Multitool
address : == SNIP ==
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
deviceTypeId : tivoRemoteDevice
displayStateId : connectionState
displayStateImageSel : SensorOff
displayStateValRaw : Disconnected
displayStateValUi : Disconnected
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 164106746
     com.duncanware.tivoNetworkRemote : (dict)
          address : == SNIP == (string)
          tivoEnumeratedIPAddresses : == SNIP == (string)
          tivoIPAddress : == SNIP == (string)
          tivoMAK : == SNIP == (string)
lastChanged : 2019-02-11 14:18:55
lastSuccessfulComm : 2019-02-11 14:18:55
model : TiVo Network Remote Control
name : Parlor - TiVo
ownerProps : com.duncanware.tivoNetworkRemote : (dict)
     tivoEnumeratedIPAddresses : 10.0.1.160 (string)
pluginId : com.duncanware.tivoNetworkRemote
pluginProps : com.fogbert.indigoplugin.multitool : (dict)
protocol : Plugin
remoteDisplay : True
states : States : (dict)
     channelSelector :  (string)
     connectionState : Disconnected (string)
     currentChannel : 0757 (string)
     isConnected : false (string)
subModel :
supportsAllOff : False
supportsStatusRequest : False
version : None
   Multitool                       ================================================================================
Sun Feb 24, 2019 10:26 am
Now installed. :D
Thanks for the pointer and the plugin. :)
As you say, it saves a few clicks and launching a shell.
I would still like to see my feature request implemented though - especially getting the output in a separate window rather than printed to the Indigo Event log. :)
Sun Feb 24, 2019 12:39 pm
Hope you find it helpful. If you see room for improvement, let me know.
