I would like to request 4 features.
First I want a way to get rid of the "unknown links" that are scattered all over my devices. They should be just as easy to erase and remove as any other item.
Second I would like to see all the the places where "RE SYNC links is listed to be relabeled. There should be one and only one master area that you click on that says "RE SYNC ALL LINKS to ALL DEVICES. It should come with a caution warning that says that it will mess everything up and it will never complete and your entire system will be unusable while it is running.
The RE SYNC links buttons on the pop ups for the single devices should clearly say that this ONLY re SYNC that device and the devices it is linked to and not start a re link of the entire system.
Third They should be a very OBVIOUS and EASY to find LARGE button that says stop all linking operations NOW.
Forth When you are syncing a keypad link to a wall dimmer module it would be very nice if it also correctly controlled the light in the keypad link module. The best I can achieve is that the keypad link button will correctly raise and lower the wall dimmer but the wall dimmer will not turn on the light in the button when raising the dimmer however it will turn off the light in the button when turning off the wall dimmer. I have to go into the wall dimmer and the keypad link and individually set up a lot of links to make the button work correctly.
My system is very large in a huge house that has one main panel and 2 sub panels. It is approaching 10 years old and the devices are failing by the box loads. I figure that within 2 to 3 years I will have replaced all of them. I have to put the new devices on an extension cord and plug them in near the main interface to define them first. Once that is done I can put them anywhere in the house and they will work but you cannot sync theme the large amount of traffic. Now that the new modules are having dual band with the radio waves in addition to the power line carried, the problems have only gotten worse.
