http to plugin
Wed Nov 01, 2017 10:15 am
http to plugin
I would like to propose an option:
in addition to update variables I would like to have a similar path to send data to a plugin:
for variables:
http:// ..../variables/theVariableName ...
add for plugins:
http:// ..../plugins/thePluginName ...
that would it make significantly easier for simple plugins. Frequent writing to variables adds overhead to the log file and the sql logger.
Wed Nov 01, 2017 12:40 pm
Re: http to plugin
That would require any random plugin to have an action defined to get that data. I'm not sure that's going to work.
Wed Nov 01, 2017 3:37 pm
Re: http to plugin
[MODERATOR NOTE] moved to the Feature Requests forum
I'm not quite sure what this request is - can you more fully explain what you're trying to solve and the approach itself?
Wed Nov 01, 2017 9:55 pm
RogueProeliator offline
Re: http to plugin
Not sure your use case, but perhaps you could make use of the inter-plugin communication / subscription system (forget the term Jay used) that was added not too long ago?
Thu Nov 02, 2017 7:55 am
Re: http to plugin
Yes same principle, the plugin receives a text string from an other plugin or here from http same principle.
Thu Nov 02, 2017 7:58 am
Re: http to plugin
Yes, if you are trying to communicate from one plugin to another plugin then I definitely recommend the broadcast/subscribe APIs we added to Indigo 7 (search on "Broadcast and subscribe").
If you are trying to communicate from some other non-plugin process via a Web API then that is a feature on the request list. We have lots of improvements scheduled (but no ETA) for the Web server and its RESTful API, including a way for plugins to define some communication channels.
Thu Nov 02, 2017 10:46 am
Re: http to plugin
THANKS !
