Dome DMOF1 ZWave On/Off Outlet With Range Boost
Sat Feb 18, 2017 12:19 pm
gskarp offline
Just wondering if there were any plans to support this device. My house could always use a boost
Sat Feb 18, 2017 1:34 pm
Re: Dome DMOF1 ZWave On/Off Outlet With Range Boost
It probably already works without a special profile, assuming they implement the standard Z-Wave ON/OFF classes. Don't be fooled about the "range boost" - pretty much every Z-Wave device that's not battery powered is a repeating slave. It does look pretty small which would be an advantage.
Fri Nov 10, 2017 9:47 am
gskarp offline
I went ahead and purchase it to turn of the TV at night since my wife and daughter often just go to bed when a net flux show ends. It seems to work great, but it constantly outputs power usage to the log. Is there a way to change how often it reports. I tried doing it with the polling setting, but that did not affect it.
Fri Nov 10, 2017 12:03 pm
CliveS offline
Interfaces > Wave > Modify Configuration Parameter
Set Param Index 1 to 0
2 to 32767
6 to 100
Does the Manufacturer show as Dome when you Sync or look at the 'Edit Device Settings' page?
CliveS
Fri Nov 10, 2017 12:08 pm
gskarp offline
Ok I will try that. What are the current settings for those parameters. When I write device details to the log it says manufacturer unknown.
Fri Nov 10, 2017 12:23 pm
CliveS offline
The defaults can be found in the online manual at https://docs.domeha.com/#configuration-command-class-parameters50, scroll up to see the whole manual.
Matt,
This Dome DMOF1 ZWave On/Off Outlet is an identical switch to the NEO Smart Power Plug (NAS-WR01ZE) that you have just added as I used the Dome info.
CliveS
Fri Nov 10, 2017 1:19 pm
gskarp offline
That's the ticket. Thanks for API suggestion/link!
