Leviton VRCS2
Fri Jul 01, 2016 6:23 am
dz1rfj offline
Leviton VRCS2
While I have had vera sticking around to handle leviton scene controllers and locks via Indigo, I want to ask when these items will be directly supported.
Vera appears to have lost the ability to communicate with my front post lights , and I really do not have the inclanation to waste time on vera. I have wasted too much time on vera!
Any chance version 7 of Indigo will support these items ?
-Brian
Fri Jul 01, 2016 8:22 am
Re: Leviton VRCS2
Improving Z-Wave scene controllers is on our to do list, but we don't pre-announce specific device support so no ETA on this specific device.
Fri Jul 01, 2016 10:44 am
dz1rfj offline
Re: Leviton VRCS2
ok, thanks. I might try a breaker reset. Vera thinks she is successfully communication with the lights, but they do not respond, and the lights work fine manually..
-Brian
Fri Jul 08, 2016 6:21 am
dz1rfj offline
Re: Leviton VRCS2
Well, looks like Vera lives a bit longer with Wall Controllers. A breaker power cycle did the trick.
Can't wait to see what version 7 brings us :)
Maybe Wall controller support, lock support, Wink plugin / or a way to connect to clear connect devices, written by Indigo ? :) I used to like keeping my technology in separate baskets, as no solution was great at everything, but Indigo is great at everything it does, and I know when they release support for something, it will just work , I wont mind relying on Indigio for everything. Regression testing seems to be something these folks get, and we are not beta testers for them!
-Brian
Fri Jul 08, 2016 6:53 am
Colorado4Wheeler offline
Re: Leviton VRCS2
A lot of us are waiting with baited breath for 7 :).
As far as lock support goes I know Matt & Jay mentioned a while back that there was a complicated, non-standard and expensive certification process to get Z-Wave locks working if you weren't an actual device, like Vera. I don't know if that is doable or not or if it's in v7 but that is my Vera's only job so if they do incorporate it then I'll have to find some poor soul to dump my Vera onto :D.
Sat Nov 26, 2016 7:11 pm
resnick offline
Re: Leviton VRCS2
So, still having trouble with my VRCS2 under 7.0.2. Remember that the device appears as 3 devices in Indigo: The controller, the bottom switch, and the top switch. The problems are:
1. The controller cannot be turned on or off, but the UI shows the on/off controls anyway.
2. When the top switch is manually turned on, Indigo shows the controller as on also. It cannot be turned off in the UI.
3. When the bottom switch is turned on, Indigo does recognize the status change.
4. The "Send Status Request" button is disabled in the UI for all three devices.
I don't know if any of the scene functions work with this device; I haven't tried them.
Below is a debug log. The controller is device 138 (Third Floor Bath Controller), the bottom switch is 139 (Third Floor Bath Fan), and the top switch is 140(Third Floor Bath Lights). In this log, I've turned the bottom switch on and back off twice, then turned the top switch on and back off twice. Glad to help debug this further, but please can we get this to work?
Z-Wave Debug polling status of node "138 - Third Floor Bath Controller" (defer list)
Z-Wave Debug RCVD nodeInfoFrame: 01 15 00 49 84 8A 0F 02 01 00 85 2D 7C 77 82 73 86 72 91 EF 2B 2C 7E
Z-Wave Debug queueing full request of "138 - Third Floor Bath Controller" (activity detected)
Z-Wave Debug polling status of node "138 - Third Floor Bath Controller" (post-activity full request)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 8B 05 2C 03 00 FF FF 51 (hex)
Z-Wave Debug ignoring duplicate full request of "138 - Third Floor Bath Controller" (activity detected)
Z-Wave Debug RCVD relaySetLevel: 01 09 00 04 08 8A 03 20 01 FF AD
Z-Wave Debug . . relaySetLevel: node 138, endpoint None, value 255
Z-Wave received "Third Floor Bath Controller" status update is on
Z-Wave Debug . . relayAssocSetLevel: cmd class 20, node 140, value 255
Z-Wave received "Third Floor Bath Lights" status update is on (from associate)
Trigger Third Floor Bath Light On
Z-Wave Debug SENT setRelayValue: 01 0A 00 13 C8 03 25 01 FF 25 AB 78
Z-Wave sent "Recirculation Pump" on
Z-Wave Debug RCVD relaySetLevel: 01 09 00 04 00 8A 03 20 01 FF A5
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 8B 05 2C 03 00 00 FF AE (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 8C 05 2C 03 00 FF FF 56 (hex)
Z-Wave Debug RCVD relaySetLevel: 01 09 00 04 08 8A 03 20 01 00 52
Z-Wave Debug . . relaySetLevel: node 138, endpoint None, value 0
Z-Wave received "Third Floor Bath Controller" status update is off
Z-Wave Debug . . relayAssocSetLevel: cmd class 20, node 140, value 0
Z-Wave received "Third Floor Bath Lights" status update is off (from associate)
Trigger Upstairs Bath Lights Off
Z-Wave Debug SENT setRelayValue: 01 0A 00 13 C8 03 25 01 00 25 AC 80
Z-Wave sent "Recirculation Pump" off
Z-Wave Debug RCVD relaySetLevel: 01 09 00 04 00 8A 03 20 01 00 5A
Z-Wave Debug SENT setRelayValue: 01 0A 00 13 C8 03 25 01 FF 25 AD 7E
Z-Wave Debug SENT setRelayValue: 01 0A 00 13 C8 03 25 01 00 25 AE 82
Z-Wave Debug RCVD requestReply1: 01 09 00 04 00 8A 03 2C 02 00 55 (hex)
Z-Wave Debug polling status of node "139 - Third Floor Bath Fan" (defer list)
Z-Wave Debug polling status of node "140 - Third Floor Bath Lights" (defer list)
Sat Nov 26, 2016 8:06 pm
Re: Leviton VRCS2
Support for this one didn't make it into 7.0, but it is still on the request list. We'll be adding additional Z-Wave hardware support in upcoming minor releases.
Sun Dec 04, 2016 11:02 am
resnick offline
Re: Leviton VRCS2
I understand that you're still working on specific support for this, but please have a look at the log because I think it might indicate a general bug:
Notice the "8B" in there. That looks to me like a status change for node 139, but you are ignoring it. You shouldn't be ignoring a status change for any device, should you?
I've worked around the problem for now by looking for the raw Z-Wave and updating the status by hand, but this seems like a bug to fix, not a feature to add. Am I off base on this?
Sun Dec 04, 2016 12:35 pm
Re: Leviton VRCS2
8B is the node ID. The command (2C) is scene related, but it isn't the central scene class that Indigo supports currently. So it isn't a bug to fix but rather a feature to implement.
Sun Dec 04, 2016 1:42 pm
resnick offline
Re: Leviton VRCS2
Ah, that makes sense. Thanks for the clarification. I'll keep my workaround in place, and I look forward to a future update with this implemented.
