Sorry for the late answer, I switched back the device to my old Stella-Z because I can't get the new device to work as expected.
Just reinstalled it and resynced it with Indigo:
Z-Wave Syncing - neighbor list updated from 1, 2, 4, 5, 6, 11, 26, 35, 42, 56, 84 to 1, 4, 5, 6, 11, 26, 35, 42, 56, 57, 71, 83
Z-Wave Syncing - assigning return route to "086 - Thermostat Wohnzimmer L"
Z-Wave Syncing - retrieved manufacture and model names: EUROtronic - 0148, General Thermostat (v2) - 00020001
Z-Wave Syncing - retrieved protocol version 3.67, app version 0.05
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Thermostat : General Thermostat (v2) (04 : 08 : 06, base 40)
Z-Wave Syncing - retrieved command classes: 20v1 40v1 43v1 84v2 26v3 86v1 80v1 31v4 72v1 77v1
Z-Wave Syncing - retrieved wake interval of 15 minutes
Z-Wave Syncing - device "086 - Thermostat Wohnzimmer L" wake interval changed to 15 minutes
Z-Wave Syncing - retrieved battery level of 65%
Z-Wave Syncing - complete
If I change the setpoint in Indigo and press the sync button on the device the device will update it's setpoint to the new value. But Indigo just displays the old value.
Also if I change the setpoint it won't get updated after the 15min intervall. Just the battery state is reported/changed.
Documentation can be found here:
http://www.eurotronic.org/fileadmin/use ... DA_eng.pdfThe device itselv can be freely rotated so the display can show in whatever direction is prefered and it is operated with 2 standard AA batteries.
