durosity wrote: I figure a plunger style sensor positioned correctly would depress when the multipoint latch is extended would be the best way of doing it. Not that it's nessesary.. it'd just be nice to have that extra info in indigo.
That's what I broke down and did for my Kevo Deadbolts; I got a pack of the Smarthome Hidden door sensors (not sure if they have a European version of those, but these work well here in the States) when they ran a sale and drilled into the back end of the bolt hole in the doorjamb just deep enough so that the bolt engages the plunger when extended. I did have to cut the collar off the sensors and remove the strike plate temporarily in order to put them in and I know it's going to be a pain to fish them out if (when) the batteries die. But for the moment, Indigo's got a solid indication of whether the bolt is secure, irrespective of what Kevo (or the Vera for the Z-wave deadbolt) thinks and a pushover alert on bolt retract when none of the registered beacons are home. And a good visual indication on my control page of door locked whenever I pull it up, although I still have to use the separate Kevo App to actually lock/unlock them remotely.
- Door+Open.png (580 Bytes) Viewed 5448 times
- Door+Closed.png (585 Bytes) Viewed 5448 times
- Door+Locked .png (564 Bytes) Viewed 5448 times
The only other issue is having to have a separate set of icons for each door orientation in my house... fortunately once I had one it was pretty easy to flip and rotate to get the rest.
