U.K. Locks
Tue Dec 08, 2015 7:56 am
col offline
U.K. Locks
I have just had this Yale lock fitted.
http://www.vesternet.com/yale-smart-liv ... -lock-2072
You can fit various modules such as the z-wave module, I assume this won't work with indigo ?
Yale asked me what z-wave software I use as they are interested in working with companies to incorporate their locks into as many systems as possible, I mentioned the problems of locks within indigo but they didn't seem to think it would be a problem.
Any thoughts on this ?
Tue Dec 08, 2015 10:02 am
Re: U.K. Locks
Z-Wave locks are (supposed) to all be implemented the same way, so our Z-Wave Lock topic applies to this one as well. Hopefully, we'll have some better news with Indigo 7.
Tue Dec 08, 2015 11:27 am
Re: U.K. Locks
Roll on Indigo 7 :D
Wed Dec 09, 2015 6:49 am
Re: U.K. Locks
Col, the manual for this seems to suggest you still need to pull the handle up to lock properly, is that correct?
Wed Dec 09, 2015 8:45 am
col offline
Re: U.K. Locks
Yes that is correct, it will lock the latch automatically but as with these kind of locks you have to pull the handle up to engage the multi point levers.
You can set a 24 hour code via the lock keypad, I am wondering if it will be possible to do this with the z-wave module using indigo (if they can get locks into indigo that is)
Wed Dec 09, 2015 9:07 am
Re: U.K. Locks
Bummer, i was hoping it had a motor to latch the multipoint lock part. Oh well, back to the drawing board i guess. :(
Wed Dec 09, 2015 9:17 am
col offline
Re: U.K. Locks
Now that would be expensive !
Wed Dec 09, 2015 12:32 pm
Re: U.K. Locks
There is one somewhere on here (not Zwave, but powered multipoint lock).
Durosity was in that thread, but you may not have been.
Wed Dec 09, 2015 1:43 pm
Re: U.K. Locks
Yeah, there's a wired 12v one that I linked to a while ago, I think it was about £450.. But then you'd also have to run wires for it, and have some kind of secure relay to action it. I was thinking the PGMs on my alarm.
Thu Dec 10, 2015 10:58 am
Re: U.K. Locks
We're looking at basic lock support if we can make it happen. We'll look at adding advanced features after that.
Fri Dec 11, 2015 9:12 am
col offline
Re: U.K. Locks
For anyone interested in the 2 types of Yale lock here in the uk and possible z-wave functions there is a blog post about theme here-
http://www.vesternet.com/blog/2015/11/y ... art-locks/
Fri Dec 11, 2015 12:54 pm
Re: U.K. Locks
It does occur to me that this might still be suitable. So long is no actual physical key is needed, i could still have one, get it to auto lock when the handle is pushed up, then disengage the lock when the pin is entered / when indigo is told to unlock the door (when/if it supports it). I don't suppose at some point you could create a video of its functionality could you? So we can actually see it in action? (Also remember to include your pin codes and exact GPS coordinates ;)
Fri Dec 11, 2015 1:41 pm
col offline
Re: U.K. Locks
Here you go,
https://youtu.be/tODlJaeRDII
Don't look 55 do I :D
Fri Dec 11, 2015 2:18 pm
Re: U.K. Locks
you don't look a day over 54.99 :D
stupidity moment.. i never even thought to check youtube. its been a bad day. :/
Fri Dec 11, 2015 2:29 pm
col offline
Re: U.K. Locks
Locks can be deceiving
