Virtual Sensors
Thu Sep 24, 2015 10:57 am
richy240 offline
Virtual Sensors
I would like to see a feature very similar to virtual on/off devices, but rendered as a sensor. I can imagine a few possibilities for this, but I would personally use them for home/away indicators for users of the system.
Thu Sep 24, 2015 5:06 pm
Re: Virtual Sensors
What would be the advantage over a variable for a single value like a sensor?
Thu Sep 24, 2015 8:50 pm
richy240 offline
Re: Virtual Sensors
Just aesthetics, really - a quick and (mildly) pretty way to see who's home, and entirely for use in the mobile app. But you can forget it, I created a SUPER simple and pretty rough plugin (my first!) that does it. I'm going to refine it (A LOT) and post it to the forums at some point. I don't know if it'll be of use to anyone else, but I like it better than using a Virtual On/Off Device connected to a variable.
Fri Sep 25, 2015 4:37 am
eme jota ce offline
Re: Virtual Sensors
IF you could also add the ability to add some math into the virtual sensor, it would be helpful to easily convert and extend existing sensor values For example, my ZXT-120 reports temperatures and sensor values in celsius, but a virtual sensor with math could easily multiply by 9/5 and add 32 to bring the sensor back into the imperialist's comfort range.
Fri Sep 25, 2015 9:44 am
Re: Virtual Sensors
Was just curious if it was something we hadn't though about. Definitely share the plugin - I suspect there are others that will find it interesting.
Sat Feb 11, 2017 12:55 pm
Topolino offline
Re: Virtual Sensors
Sorry if it's not cool to revive an old thread. I thought my question was relevant:
I'm implementing a small and inexpensive Wemos board to post updates to Indigo via Wifi. The example I am following are using Domoticz, and that platform seems to have a way of setting up virtual sensors that you can populate with data with an external source. I think it sounds like a great feature.
http://www.instructables.com/id/ESP8266-Soil-Moisture-Sensor-to-Domoticz/?ALLSTEPS
Is this something that you have considered since last time this was brought up?
Sun Feb 12, 2017 3:23 pm
Re: Virtual Sensors
There are a couple of approaches you could take for that in Indigo. You could just have a script that populates/updates Indigo variable values with the data. The other option would be to create a new plugin that defines sensor devices for the hardware. The Indigo SDK download has examples of all the device types, including binary and variable sensor devices. If you know python I would look into that approach. The plugins for simple devices can be pretty straightforward to create and the SDK has some good examples.
