Is it possible to remove use of the open command in the LaunchAgent com.perceptiveautomation.IndigoServer2.plist per default?
I have removed the 'open' command from my computer and after every update of Indigo I have to edit the LaunchAgent again as Indigo is the only application that make use of the LaunchAgent there for some reasons I don't understand.
I just change the ProgramArguments to
/Library/Application Support/Perceptive Automation/Indigo 6/IndigoServer.app/Contents/MacOS/IndigoServer
Than I can even set the KeepAlive to True. There even is a note that True can't be used as this would just restart the open command instead of Indigo. Is there any speacial reason why the IndigoServer isn't called directly? I'm using it this way for month now without any noticeable problems. Would be great if this could be the next default.
