[SOLVED]AND & OR in Triggers
Wed May 27, 2015 5:03 pm
george99 offline
Right now from what I can tell, you can only set the conditions of a trigger to be all under 1 OR statement (any), or all under one AND statement (all).
It would be nice if I could combine multiple instances of this. For example:
AND
        OR
              var A = true
              var B = false
              var C = false
        OR
              var D = true
              var E = true
              var F = false
       var G = true
In English, at least one of the 1st OR set must match. At least one of the 2nd set must match. var G must always be true.
I hope that is clear.
Wed May 27, 2015 5:06 pm
george99 offline
Re: AND & OR in Triggers
I should add that technically, I can probably accomplish this with multiple triggers and a lot of variables, however, it would be quite cumbersome. Much more convenient withing 1 trigger's condition.
Wed May 27, 2015 11:11 pm
Have a look at the Docs under Conditions:
http://wiki.indigodomo.com/doku.php?id= ... conditions
There's a little-known solution for what you're asking by using the 'option' key when you click the + button to add a condition.
Thu May 28, 2015 6:32 am
george99 offline
Nice! Thanks.
