Now that Honeywell has finally provided an API for the Comfort Control portal specifically for working with home automation companies and consumers (You can register to get a key here: http://www.ecc.honeywell.com/api, it's in beta but available, just have to wait a few days for the key) it would be great to see a plugin to interface with Indigo. This would then open it up to anyone that has a Redlink enabled thermostat or Honeywell wifi thermostat to instantly integrate with our home automation systems. Considering this is the only way to nicely control the majority of mini-splits (Including as the common Mitsubishi Mr Slim) that traditionally couldn't be managed short of a touchy IR blaster setup such a plugin should open up access to a lot of people.
http://honeywell.com/News/Pages/Honeywe ... opers.aspx
