Conditional actions
Tue Mar 18, 2014 7:24 am
Swancoat offline
Conditional actions
Although not directly related, (but results in the same kind of duplicating of triggers), it'd be cool if instead of just a condition parameter on the triggers, if there could be an alternate result. Kind of an if/then/else structure.
Currently, I may have triggerX happen, but what I want executed depends on some condition. Currently this means I have to do two triggers, one with the 'positive' condition, and the other with the opposite.
So instead of two triggers:
when X, then if Y do A
when X, then if not Y do B
It'd be nice if it could be:
when X, then if Y, do A, else B
(and if A and B are action groups that allow the same kind of conditioning structure, you could actually nest up a couple of these and cut down the clutter immensely).
http://nerdhome.jimdo.com
Tue Mar 18, 2014 7:43 am
Re: Conditional actions
This has already been requested in various forms and is on the list for future consideration.
[MODERATOR NOTE] Split into a separate topic since it wasn't directly related to the previous topic.
Tue Mar 18, 2014 9:42 am
zabazoom offline
+1
Tue Mar 18, 2014 6:43 pm
Remember this can be done as a script.. basically ignore the conditions field, then under the actions tab write a small script to do X if this, and Y if that. More fiddly i know, i'd much rather a GUI way of doing it.. but it does make for a tidier selection of triggers!
Tue Mar 18, 2014 6:56 pm
eme jota ce offline
+1
Wed Mar 26, 2014 2:48 pm
AndyVirus offline
Also +1 :)
