Sorry for my late reply im just building a new home so are busy keep an eye on the workers
please see answers below each question.
Koburg/jaga01, does the UI for the Matrix device allow you to "Turn on"/"Turn off" the whole (unidentified) device in Indigo?
No not at All there is only one ON/OFF and it is NOT working and a dimmer not updating dimmer level. it will only work together with your scene plugin (please se picture attached how the device is included.)
Jaga's request to turn off the light connected to the endpoint 5/button 1 looks like it should work out of the box by just turning on/off the whole device, without worrying about endpoints / multiple buttons not existing, unless because it's reporting as multilevel-switch, the UI doesn't provide an on/off button?
Yes button on is working to turn on/off the build in relay as standard you can choose another from parameters
I'm presuming you both have the Matrix set to use Central Scene commands (param 7 = 1, the default), so you're already happy with processing incoming commands from the buttons using the plugin?
Yes and that's is all that are working for now and only single association are working which is useless for this device if you want it to control a "twin" matrix
So I just need to properly facilitate turning on/off the attached dimmer (endpoint 5), on/off the buttons, and the colours of the buttons?
Yes please. the colors can be set from parameters for now but sure if it could work from plugin.
another important thing is the multi association function to work.
- screen.jpg (435.43 KiB) Viewed 3183 times
