howartp wrote:
Having written all this, I presume you're aware you can add multiple nested conditions to a trigger? Hold the option key on keyboard when pressing + button in the condition UI.
Gangotti wrote:It would be great if you could use multiple devices to trigger single actions, for example: If device 1 is on AND device 2 is off then trigger action A. in this instance both devices need to be on to trigger the action. you could take it a step further and say if device 1 OR device 2 is on trigger Action B. In this instance either device would trigger the action. I find that I am building many virtual devices just to contain a little bit of operational logic to run my trigger and schedules. To build that into the Triggers section would make it very flexible. Thoughts?
howartp wrote:If you want to OR 18 devices as in your scenario then a virtual device is the way to go.
Two triggers, one virtual device, no hassle to add a new window.
If ALL of the following are true
Condition one
Condition two
Condition one
If ALL of the following are true:
Condition two
Ooh, ooh
