Device Validation and Error Messages
Thu Jul 11, 2019 6:19 am
This is probably a niche case and extremely pedantic. It may not warrant any action, so bear with me.
Screen Shot 2019-07-11 at 7.12.09 AM.png (13.19 KiB) Viewed 1624 times
I have a device with a group of seven checkbox controls where I am requiring users to select at least two of them. It doesn't matter which two. When returning the error message dict, it doesn't seem like good UX design to highlight all of the controls or all the unselected controls, so instead I plan to highlight the label for the group (an alternative would be to highlight nothing at all and rely solely on the 'showAlertText' dialog). Regardless, the config UI returns the expected "Error validating fields. Hover over the red field labels above to see the error reason." on error.
Screen Shot 2019-07-11 at 7.14.31 AM.png (15.67 KiB) Viewed 1624 times
In this case, the error message isn't technically associated with a field label, or nothing is highlighted red if I go just with the alert dialog. So I would suggest the device config dialog alert message be changed slightly to something like: "Error validating fields. Hover over any red label(s) above to see the error reason." (or something like that), which would be more inclusive of potential conditions within the config dialog.
Thu Jul 11, 2019 6:31 am
berkinet offline
Re: Device Validation and Error Messages
DaveL17 wrote:
This is probably... ... extremely pedantic.... .
Is that a fault? :lol:
DaveL17 then wrote:
...So I would suggest the device config dialog alert message be changed slightly to something like: "Error validating fields. Hover over any red label(s) above to see the error reason." (or something like that), which would be more inclusive of potential conditions within the config dialog.
No less pedantic, but maybe more broadly applicable, how about the ability to, optionally, provide the text of the error message? Then you could have...
    Error validating fields. A minimum of two options must be selected.
Thu Jul 11, 2019 8:42 am
I think a relatively simple change might be to just not show any text there if showAlertText is used (I don't recall if we already do this, but I suspect not). So you could put your full validation error(s) into the alert sheet and the underlying built-in mechanism would just be bypassed. We'll look into that next time we're in the plugin dialog code.
Question: any reason why you're using multiple checkboxes rather than a list? That would be a single control where you can select multiple things but with a single point for validation.
Thu Jul 11, 2019 9:02 am
If you ask my employer, no.
If you ask my wife, yes. :D
Thu Jul 11, 2019 9:04 am
jay (support) wrote:
I think a relatively simple change might be to just not show any text there if showAlertText is used (I don't recall if we already do this, but I suspect not). So you could put your full validation error(s) into the alert sheet and the underlying built-in mechanism would just be bypassed. We'll look into that next time we're in the plugin dialog code..
Thanks Jay. I think that's a great compromise.
EDIT -- I can confirm that the error text still appears when only an alert dialog is used.
My excuse is going to be that I want to pre-select multiple things and in the back of my mind, that isn't possible with a list--but now I'm second-guessing that assumption. I will go back and look again. A list would be more intuitive, I think.
Thu Jul 11, 2019 9:10 am
Yep, looks like I was wrong on that. You can indeed have multiple values as the defaultValue. A list it will be.
My suggestion still stands. :D
Thu Jul 11, 2019 12:25 pm
Another thing that you can do (I think) is to use a callback such that whenever the list selection changes it will call back to your plugin. You can use that callback to validate how many things are selected and show/hide appropriate label fields. I'm pretty sure the callback works for lists, but I might be misremembering...
Users browsing this forum: Google [Bot] and 2 guests
