Ok, beta available here:
https://github.com/howartp84/FontAwesome/releasesPreRequisites:- Need to install Pillow package, to enable coloured icons. "sudo pip install Pillow" should do the trick
- Need to register for a free account at https://cloudconvert.com/ - this is doing the conversions from SVG to PNG. You can do 15 minutes worth of conversions per day for free, at ~5 seconds per conversion, which is around 180 icons per day.
- OPTIONALLY register for a Pro account at https://fontawesome.com/
The plugin comes with the v5.8.2 free icons builtin; you can download and save Pro icons from
https://fontawesome.com/download (the Desktop version) and extract the content of the "svgs" folder into \Library\Application Support\Perceptive Automation\Indigo 7.3\Plugins\FontAwesome.indigoPlugin\Contents\Server Plugin\svgs. (There's a text file called "Paste PRO files here.txt"
Once installed, grab your CloudConvert API key from
https://cloudconvert.com/dashboard/api/v1/keys and enter it in the plugin config.
Create either a "Font Awesome Single Icon" device, or a "Font Awesome Downloader" device.
The former asks for an icon name (eg 'alarm-clock') and style (eg 'solid') taken from the FontAwesome icon gallery at
https://fontawesome.com/icons?d=galleryThe latter lists all the icons in the plugin, free and/or PRO, for you to multi-select.
Upon saving, the icon(s) you've selected/typed will download. You can go back in at any time and select or type (a) new icon(s) - they'll download when you hit save.
See the Indigo log for the folder location.
Have fun, see you how you go...
